Engine knocking
Old Oct 29, 2004 | 08:06 PM
f23accord's Avatar
Default Engine knocking
Im about 3k shy of 70k on my car and my **** knocks, that damn click click click noise.....my friend told me when his **** started doin that too he took it to the dealership to try to fix that and they wouldnt do it, he was trying to give them money to fix it but they said its normal in hondas after a while on the motor.....is there anyway i can get like a valve tunin or what not? When i first turn the car on you can hear it pretty good but after its warmed up its not that loud but you can kinda still hear it.....someone hook it up with some answers
Old Oct 29, 2004 | 09:41 PM
momstaxi's Avatar
Default Re: Engine knocking (f23accord)
try doing a valve lash adjustment, that could be your problem, there are detailed instuctions in any helms or chiltons manual.
Old Oct 30, 2004 | 04:46 AM
TOAB's Avatar
are your valves ticking? or do you have a knock... its not normal to have your engine knocking.
Old Oct 30, 2004 | 12:53 PM
f23accord's Avatar
Default Re: (TOAB)
Its more of a ticking i guess
Old Oct 30, 2004 | 01:12 PM
TOAB's Avatar
Default Re: (f23accord)
check/adjust your valve clearances
Old Oct 30, 2004 | 02:12 PM
f23accord's Avatar
Default Re: (TOAB)
How can i go bout doin that, im not too knowledgable with motor internals
Old Oct 30, 2004 | 02:59 PM
TOAB's Avatar
hmm first look up what the clearances should be... then go find some feeler guages. pop off your valve cover and check them with the gauges... some cars the motor has to be at operating temp, some have to cold etc... go buy a chilton, or haynes.
Old Oct 30, 2004 | 08:11 PM
daveedd357's Avatar
what I have found is that the honda accord and prelude engines have a problem with the main bearings. the usually get loud with hard use, but as the dealer said it will last forever like that. you always have the option of having them replace them, but they will charge you an arm and leg maybe a toe too
Old Oct 30, 2004 | 08:26 PM
TOAB's Avatar
ummm if your main bearings are so worn theyre making noise you should probably replace them... do it yourself its not hard.
Old Oct 30, 2004 | 10:02 PM
i20ar's Avatar
Default Re: (TOAB)
Hmm my car had a ticking noise when i got it it had about 65k on it .. all i did was replace my pvc valve... it cost like 5 bucks and took 3 mins to change.. it located on top of yoru valve cover towards the back.. pust pull it out then out of the hoes its attached to .. i used plyers to pinch the metal band... then install the new one using the reversed process iunno if this is it but it helps out with sum of the noise
Old Oct 31, 2004 | 07:58 AM
f23accord's Avatar
Default Re: (14aZnS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 14aZnS &raquo;</TD></TR><TR><TD CLASS="quote">Hmm my car had a ticking noise when i got it it had about 65k on it .. all i did was replace my pvc valve... it cost like 5 bucks and took 3 mins to change.. it located on top of yoru valve cover towards the back.. pust pull it out then out of the hoes its attached to .. i used plyers to pinch the metal band... then install the new one using the reversed process iunno if this is it but it helps out with sum of the noise
That doesnt look like under the hood of a 6th gen though
Old Oct 31, 2004 | 08:15 AM
twkdCD595's Avatar
our motors always sounds like a sewing machine.
try the valve adjustment first... it is cheap and easy.
Old Oct 31, 2004 | 07:33 PM
i20ar's Avatar
its should be in the same location isnt it?
Crx_Civic
Nov 2, 2007 10:06 AM
redpeppers
Jul 26, 2005 02:33 PM
jako_X
May 1, 2004 12:45 PM
EuN_TeK
Mar 16, 2004 07:22 AM
Yuleluder
Aug 29, 2002 07:20 PM
