B20????
Old Dec 20, 2001 | 09:53 PM
The Brown Kid's Avatar
Default B20????
I wanted to know what tranny and mounts and ecu i would have to use. also is the b20 better than the b16a1 stock and if not what about with like new pistons cuz i heard the compssion ratio is horrendous. Oh yeah whats the diff. between a b20b and a b20z?
and last, where can i get one and about how much??
-thanks for your help guys. "Wutang n*gga, dats whats up"
Old Dec 20, 2001 | 10:09 PM
SiREF8's Avatar
Default Re: B20???? (Iron Flag)
Hey check out <U></U> http://www.b20vtec.com I know the most people just use the B16a tranny, but any b-series bolts up to it so take your pick. If I'm wrong someone here correct me. As for mounts there are companys that make mount kits like hasport, place racing and etc. so take your pick.
Old Dec 21, 2001 | 01:59 AM
Backyard Speical's Avatar
We have a JDM B20 in stock right now. please give us a call for more info.
Old Dec 21, 2001 | 12:01 PM
rainforest's Avatar
if you putting it into ef then you need a mount kit like place racing or hasport. you need to change the intake manifold to the ls cause the b20 is to tall. the b20b has 8.8 comp and makes 126hp and the b20z has 9.6 comp and 146hp so if you can go with the b20zout of a 99-00 crv.
Old Dec 21, 2001 | 12:19 PM
badCRX's Avatar
New User
Default Re: B20???? (SiREF8)
Call HASport and speak to Joe, he has a B20 in his Ef I thought last I talked to him, he may also have some computer solutions for you as well. I believe the website should have the number... http://www.hasport.com
Old Dec 21, 2001 | 06:06 PM
customx_'s Avatar
New User
Default Re: B20???? (badCRX)
look at front page...
http://crx.honda-perf.org/index.html
Old Dec 21, 2001 | 11:02 PM
B16CRX's Avatar
Default Re: B20???? (mindtrix)
There is alot of good info here too www.crvtec.com
Use a vtec head on it. I'm hoping to upgrade my B16A to CRVTEC soon. My friend had to go out and get a 01 ITR, so I have to make sure I stay faster
Old Dec 22, 2001 | 07:11 AM
mini-cRx's Avatar
Default Re: B20???? (B16CRX)
i want to do a b20z in my crx si i dont want vtec. can anyone explain good how the wiring and part replacement and all please help thanks
Old Dec 22, 2001 | 11:52 PM
KS-R's Avatar
Default Re: B20???? (mini-cRx)
Hm... I think the simplest option for a straight B20 into a CRX without Vtec would be to use a 88-91 Prelude ecu... Those are 2.0L and they're Pre-OBD.. So it should work(theoretically) Does anybody know for sure...
I have the ecu available if you need.
Old Dec 23, 2001 | 04:45 AM
mini-cRx's Avatar
Default Re: B20???? (KS-R)
it wouldnot work i think i want to know how to wireup a crv motor and what i need thanks anyways
Old Dec 23, 2001 | 11:05 AM
KS-R's Avatar
Hey.. what model of CRX do you have? If it's an Si... then I think you should be able to run the car with the PM6 ecu... Whether if it'll have enough fuel will be a different story... Due to the fact that the ecu is for a 1.6L and the motor is a 2.0L... So you could use a PR4 (90-91 TEG ecu) That'll be a little better. Cause basically a B20B/Z is just a larger D16a6 or a B18a..
For the intercahnge of parts.. You'll need to change the injectors and distributor. Injectors.. you might want to use some 92-95 Prelude Vtec injectors (they flow more). Make sure they're Vtec ones... cause the Non-Vtec injectors are Saturated injectors and they won't work properly.
Next.. the distributor that you need is again... from a 90-91 Integra... They should bolt right up... cause the B20B/Z motor basically uses an LS head...
So take the wiring harness off your old motor.. and just transfer if over to the B20B/Z motor and plug it all up and you should be able to start. vroom vroom.
If you have any other problems or questions feel free to post here or email me. Good luck.
Old Dec 23, 2001 | 11:12 PM
thanks guys and i got an (HF) oh yeah no one ever answered my ?? is the b20 stock(non-vtec) faster than a b16a1?? Anyways thanks for all tha help....
Old Dec 24, 2001 | 06:43 AM
DTAYLOR's Avatar
New User
I have the same question. How much power with b20 none vtec with 11 or 10.50 compression? maybe some headwork. Sounds like a lot of fun in a crx roadrace-track car. My zc is to slow now days.
Old Dec 24, 2001 | 12:50 PM
91ED7Si's Avatar
well the prelude has the b20a5 so i dont see why it wouldnt work.
Old Dec 24, 2001 | 01:03 PM
KS-R's Avatar
What do you exactly mean by FASTER?... A B20 is about 140hp stock with about 130ft/lbs of torque (around there) and a B16 has 160hp & 110ft/lbs of torque.
It's hard to say which would be faster.. Assuming the two motors in the same body style. I know that the B20 would be great for track... pulling right out of the turns, but on a straight away.. The Vtec would shine...
Hope that helps a bit.
Old Dec 24, 2001 | 01:52 PM
Blown90hatcH's Avatar
The two motors stock...the B16a wins. You can use your HF harness.
Old Dec 27, 2001 | 12:58 AM
Mazmay's Avatar
Default Re: B20???? (Blown90hatcH)
I've got a b20b in my crx
I am in fact using the crx si injectors, and distributor. I'm currently running the crx si ecu (pm6?)
but the 90-91 non-vtec teg ecu will work as well (pr4) but make sure you get the 90-91 ecu.
the car feels nice and torquey...I'm very very satisfied...haven't run it at the track yet.
Old Dec 27, 2001 | 05:33 AM
Phatwhippin_CRX's Avatar
Default Re: B20???? (Mazmay)
How in the hell are you using a D16 distributor? D series on B series, = no work..? WTF? Has to be a typo...
Old Dec 27, 2001 | 08:12 AM
Doodoo's Avatar
Default Re: B20???? (Phatwhippin_CRX)
You can use the CRX distributor. You just cannot totally bolt it up. I used mine for a few hundred miles bolted by 2 bolts. Worked fine. But for piece of mind I went out to buy a 90-91 distributor.
9.3.S.I.L.U.D.E.
Aug 19, 2009 10:39 AM
Subterraneous
Aug 24, 2006 08:05 PM
allmota1.8
Sep 14, 2003 01:59 PM
Rydaddy
Feb 23, 2003 10:51 PM
Aquafina
Feb 13, 2003 12:22 PM
