Civic Brake Line Replacement (Under Car...)
Ok so I have a large problem. Turns out that my exhaust in the back was rubbing on one of the break lines near the lower control arm and wore through it. So now, I have no brakes.
Now as far as i know, nobody sells the entire replacement line, not even a dealer. The shop manual tells nothing about the size or replacement or repair if possible. I wanted to go to the auto parts store and just get a 10ft length of line, remove the broken line and bend myself a new one.. but i dont know the pipe size!
Is repair of just the section possible? I have been thinking no, since it is a brake line and not something you really want to try and rig together. ANY help here is appreciated...
Modified by JDM_Ej at 8:06 PM 10/29/2004
yes, you can get the line from the dealer.
http://www.slhonda.com - Parts section at the top left
(Brakes are under the 'chassis' section)
You can fix the section, if you really want to try. Id do it by removing a section, flaring both ends and inserting a new secion w/ dual male ends. If thats possible.
Order these......
http://cgi.ebay.com/ebaymotors...33562
Or this........
http://www.hondaautomotivepart...BS%29
Or use this...........
http://www.duct-tape.com/?refe..._TAPE
Or this........
