obd0 motor into obd1 car
Old Oct 29, 2004 | 01:28 PM
1992tegRS's Avatar
Default obd0 motor into obd1 car
i know this is possible but how my mecanic is stuck. should i go to a shop that does engine swaps? are there wiring harnesses out there 2 make my wires connect?
Old Oct 29, 2004 | 03:48 PM
smart monkey's Avatar
Default Re: obd0 motor into obd1 car (1992tegRS)
what motor are you putting in? I figure you have a 92 rs. most of the time you just use the stock engine harness and add wires for various sensors and extend some. if you can give more info that would help
Old Oct 29, 2004 | 05:14 PM
1992tegRS's Avatar
adding JDMb16a1(OBD0) into 92 RS integra b18a(OBD1)
Old Oct 29, 2004 | 10:52 PM
use your old harness and use a OBD1 dist and ecu and use the old vss from your old trans. also you can use your old exh man with the old O2 and this is the bulk of it. add wires for vtec and vtec oil pressure
92integraVTECgsr
Mar 30, 2010 05:58 AM
88zchatch
15
Mar 20, 2009 12:06 PM
ef dino
Jun 1, 2007 07:04 AM
DA jeshy
Feb 7, 2006 04:39 PM
KevronsEG
11
Jun 28, 2002 09:23 AM
