HOW TO INSTALL A FRONT STRUTBAR?
i just bought an arospeed strutbar. the question is, how to install it. do i need suspend the car with jackstands or what do i need to do?
Modified by ram0869 at 1:06 PM 10/29/2004
no.... <U>DO</U> raise the car....ur struts will <U>NOT</U> fall off as they are still attatched at other points (knuckle and fork). just raise the front when u install.
this way you can pre-load the bar and it will be more effective.
-chris
-chris
I have the Arospeed front strut bar. No reason to raise the car, just take the three nuts off on each side, put the strut bar on the bolts and put the nuts back on.
Actually what does the pre-load do, should i reinstall it your way?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94hondaaccordlx »</TD></TR><TR><TD CLASS="quote">Actually what does the pre-load do, should i reinstall it your way?</TD></TR></TABLE>
when the car is on the ground....the chassis is somewhat squatted\flexed.....when it is raised, the stress on the front is taken out. So installing the bar in while it is in the air will result in a more effieciently installed brace.
just raise it enough to get the load off the wheels....
zcivicz
Feb 23, 2003 05:43 AM
