Strut bar install problems....
Old Apr 30, 2003 | 12:25 PM
Twigster311's Avatar
Default Strut bar install problems....
Yea i know, by far the easiest install in existance.....and I cant do it.
I drove around for a while without the (oem) itr strut tower bar on, and not it doesnt line up. If i put it on one side, it's not long enough for the other it seems....
Any ideas ?
Old Apr 30, 2003 | 12:26 PM
RTW DC2R's Avatar
Default Re: Strut bar install problems.... (Twigster311)
is the car sitting flat
Old Apr 30, 2003 | 12:37 PM
Default Re: Strut bar install problems.... (CACK ***!)
i'm working on other parts, so currently the car is jacked up evenly and supported on all 4 points. Could this simply be causing it? I feel stupid.....
Old Apr 30, 2003 | 12:38 PM
RTW DC2R's Avatar
yup
CWESTINAP1's Avatar
which strut bar are you trying to install?
Old Apr 30, 2003 | 12:44 PM
GRM Scott's Avatar
25 Year Member
put it on the ground (bits that affect suspension should always be torqued with the car's weight on the wheels for future reference, so even if it did fit you wouldn't want to snug it down till the car was in an unstressed resting state on its wheels).
Old Apr 30, 2003 | 01:49 PM
Default Re: Strut bar install problems.... (Aleph)
Car is lowered and on the ground. Still not fitting. (btw- oem itr brace. I have another gsr brace in my garage and it does not fit in the exact same way. It's off by a little less than a Centimeter.
Old Apr 30, 2003 | 03:04 PM
kepani's Avatar
were you ever in an accident (or maybe prev. owner was if your car is used?). maybe the chassis is slightly tweaked.
Old Apr 30, 2003 | 03:10 PM
B2FiNiTY's Avatar
Is the bar complete? Everything is bolted up except the sides right?
Old Apr 30, 2003 | 03:38 PM
Floyd's Avatar
Default Re: Strut bar install problems.... (B2FiNiTY)
Did you remove the bar yourself? Did it ever fit?
Old Apr 30, 2003 | 03:52 PM
ScaleExtric's Avatar
Default Re: Strut bar install problems.... (Floyd)
This same thing happened to me..All you gotta do man..is get a hammer and hit the studs out a little ..just tap one side...out. Then it should fit fine. My car did the same ****..
MechEng
Dec 29, 2008 09:40 PM
Khanster
Nov 20, 2008 06:48 AM
mrdeadman
Apr 20, 2006 04:24 PM
tsdenny
Sep 29, 2004 09:03 AM
fresh99si
Mar 25, 2003 03:13 PM
