No performance atfer swap stock cams with jun type3 cams and valve springs..
Old Oct 28, 2004 | 11:06 PM
Fueling's Avatar
Default No performance atfer swap stock cams with jun type3 cams and valve springs..
I have a Honda Civic EK4 B16A engine. Accesories upgrade exhaust system, Jun type 3 camshaft , Crower valve spring retainer, but i felt that my car power was not good as before ( stock )...Is there any suggest to know what exact problem.
Is there any perfomance by using Apex-i A-AFC & Power Enterprise Vtec Controller , Throttle body , Header, Metal Gasket...?
Old Oct 28, 2004 | 11:09 PM
slammed_93_hatch's Avatar
Default Re: No performance atfer swap stock cams with jun type3 cams and valve springs.. (Fueling)
YOU HAVE TO TUNE TO MAKE POWER.
have you even dyno'd the car to see what happened?
afc anit gona cut it
Old Oct 28, 2004 | 11:21 PM
igyloo's Avatar
higher compression and TUNED ECU
Old Oct 28, 2004 | 11:52 PM
VeilSide_Mas's Avatar
Default Re: No performance atfer swap stock cams with jun type3 cams and valve springs.. (igyloo)
Yes you definitely need higher compression to run jun 3s, it's just not worth it to put jun3s onto a b16a with stock compression
However like what those 2 above me said, tune it...cams aren't plug and play stuff. AfterI put in my skunk2 stage2s, it felt much weaker than my ctr cams but after tuning the next day..it was
Old Oct 29, 2004 | 01:03 AM
ATS*Mark's Avatar
OG triple OG
Default Re: No performance atfer swap stock cams with jun type3 cams and valve springs.. (VeilSide_Mas)
yup
Old Oct 29, 2004 | 05:02 AM
honda eg9
Guest
Posts: n/a
you NEED the jun ecu and tuning my friend ran a stock ecu while waiting for the jun ecu and it ran like crap
Old Nov 1, 2004 | 06:51 PM
Fueling's Avatar
If i change type r piston ,metal gasket and throttle body will that make much different and increase my engine compression .....
Old Nov 1, 2004 | 06:54 PM
Fueling's Avatar
Default Re: No performance atfer swap stock cams with jun type3 cams and valve springs.. (slammed_93_hatch)
Not yet do any DTNO Test yet. if install Apex-i V-AFC can get a better respone.
Old Nov 1, 2004 | 07:10 PM
Discosteak's Avatar
babblefish
JAndrinich
Engine Machining & Assembly
13
Jan 4, 2016 07:09 AM
OrangeTeggy
May 19, 2009 05:14 PM
soulfly
19
Feb 17, 2006 04:37 PM
ahead
Aug 24, 2002 12:55 PM
90crxsir
Oct 24, 2001 04:22 AM
