Valve cover removal question
Old Dec 20, 2001 | 06:07 PM
oryanh's Avatar
Default Valve cover removal question
I really don't want to have to buy a Helm's manual for this... Could someone include the valve cover bolt torque specs? And which ones if possible?
Any other tips would be great. I'm removing in order to cut it for cam gears. I've purchased "HondaBond" and another valve cover gasket with spark plug seals. anything else???
thanks!
-lazy
Old Dec 20, 2001 | 06:15 PM
VaporTrail's Avatar
New User
Default Re: Valve cover removal question (oryanh)
torque spec...ugh...hand tight, then a half turn. You don't gotta break out the torque wrench for this one Put a little Hondabond (aka Permatex grey) on the corners by the cam cap edges, and you're set.
Old Dec 20, 2001 | 06:24 PM
oryanh's Avatar
Default Re: Valve cover removal question (VaporTrail)
hehe... thanks. Feeling a little **** retensive today.
Speaking of pains in the anus. Is it tough to install cam gears? In other words, can I trust a local tuning shop?
I'm thinking about doing this myself.
Old Dec 20, 2001 | 07:01 PM
BryanSprinkel's Avatar
If you have nevr done it , PAY someone who has! You dont want to leave anything out when messing with the timing belt.
Bryan
Old Dec 20, 2001 | 07:19 PM
arren123's Avatar
I remember my valve cover was hard to remove. I had to pry it loose with the end of the hammer. The torque specs for the bolts are low. So don't overdue it because you'll snap the bolt. 12 ft-lbs should be good enough. If you do a search, I think people said that they snap at 15 ft-lbs.
Old Dec 20, 2001 | 07:26 PM
Floyd's Avatar
Default Re: Valve cover removal question (arren123)
Haynes has the spec at 86 in-lbs, and the four inner nuts should be tightened first, then the four outer nuts.
Old Dec 20, 2001 | 11:02 PM
t's Avatar
t
Default Re: Valve cover removal question (Floyd)
All these Jokers on the board. 7.2ftlbs
Old Dec 21, 2001 | 01:44 AM
Back in Black's Avatar
Rather OG
120 in lbs, or 12 ft lbs...
jason- who just repaired a broken valve cover bolt 3 weeks ago
Old Dec 21, 2001 | 02:06 AM
BudMan's Avatar
Default Re: Valve cover removal question (Darth VadeR)
The bolts are only $3-5 each.....trust me - go buy a couple to have on hand! Nothing says ****! like hearing one snap.....especially if it's your only car & you now have to go buy one
Oh yea - go buy a BFRM - rubber mallets work wonders on stuck valve covers!
Old Dec 21, 2001 | 03:19 AM
Jason's Avatar
Default Re: Valve cover removal question (BudMan)
ditto, I've busted a few bolts as well...I know have at least two of each (inner and outer) bolts just in case
Old Dec 21, 2001 | 06:50 AM
Batoutahell's Avatar
Yeah and make sure you get a manly 32oz. BFRM, not a wussie 24oz. You never want to be caught with not enough whack.
Old Dec 21, 2001 | 07:03 AM
sackdz's Avatar
Default Re: Valve cover removal question (Batoutahell)
Haha, good quote.
new sig
Old Dec 21, 2001 | 07:34 AM
TypeRdude's Avatar
Default Re: Valve cover removal question (sackdz)
I've think it'ss 8ft lbs in my Alldata system, or 96in lbs.
You should do something like 45in first then 96 to make it more even.
Old Dec 21, 2001 | 08:00 AM
davew's Avatar
Default Re: Valve cover removal question (TypeRdude)
and never work on it while the motor is hot...thats why so many people break and strip the bolts. alum motors should always be cold when you torque anything on them.....
dave w
Old Nov 5, 2008 | 01:53 PM
The Dude's Avatar
Banned
The valve cover does not use bolts. The cap <U>nuts</U> are torqued to 7.2 ft/lbs. as stated above.
There are also gaskets are under the cap nuts, might as well get new ones as you have the rest of the gaskets.
Torque the nuts to 5 ft/lbs first, then right rear, left front, etc. to 7.2 ft/lbs.
Spec from 1998 Helms
Merry Thanksgiving---&gt; http://www.meilinkvision.com/misc/service.pdf
Modified by The Dude at 4:59 PM 11/5/2008
Old Nov 5, 2008 | 01:56 PM
get RIGHT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Batoutahell &raquo;</TD></TR><TR><TD CLASS="quote">Yeah and make sure you get a manly 32oz. BFRM, not a wussie 24oz. You never want to be caught with not enough whack.</TD></TR></TABLE>
Hahaha. Nice, 7 year's later that is still a good one.
cryingsuns
Apr 16, 2012 09:58 PM
BigC-ivic
Aug 3, 2005 08:47 PM
B16ADelSol
Jun 4, 2004 01:14 PM
hott-nix
Apr 15, 2004 01:01 PM
oryanh
Jan 6, 2002 09:48 AM
