Tranny or Cable??
Ok i have a problem. I was driving my car a few weeks ago, and i was trying to turn a corner when my stick shift went haywire and wobbly. It seems to be stuck in 3rd gear but the stick shift goes all over the place, and i can't get it in in any gear. Can anyone suggest what exactly this could be and how much it would possibly cost to fix it?? Has anyone heard of this before?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drdisco69 »</TD></TR><TR><TD CLASS="quote">Sounds like a broken shift linkage.</TD></TR></TABLE>
or a missing bitch pin
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HatchBox »</TD></TR><TR><TD CLASS="quote">or a missing bitch pin</TD></TR></TABLE>
LOL @ bitch pin. I forgot about that name.
jack your car up (once the exhaust is cooled off of course) and look where the linkage attaches to your shifter. there is a chance that the self locking bolt may have failed and fallen out or something. it happened to me once and it sucked! i limped all the way to work but it was an easy fix with the right hardware.
Mine once just fell out of place cause I put the rubber stopping thing in wrong so it didn't stop it from falling off easily. I'm not sure how much it costs, I can only tell you it's pretty easy to replace. I know my hasport one is like $150, but it's a aftermarket linkage.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX_1.8T »</TD></TR><TR><TD CLASS="quote">jack your car up (once the exhaust is cooled off of course) and look where the linkage attaches to your shifter. there is a chance that the self locking bolt may have failed and fallen out or something. it happened to me once and it sucked! i limped all the way to work but it was an easy fix with the right hardware.</TD></TR></TABLE>
yeah, do that first, that happen to mine too a couple of days ago. look under your car!
well for one thing, i don't have a jack right now, and i the car is stuck at my moms house in canada, so i'll hurry and get it jacked up as soon as i can. But what am i looking for?? As you can tell, i'm still learning so be patient with me
my car did that exact same thing, but stuck in 2nd gear.
cause: previous owner had cut 2" out of the middle of his shifter to make a "short shifter". well the weld finally gave up and snapped in half.
it was ok tho.. i was right beside a dealer so i just did a 2nd gear start and pulledin there. went to the local performance shop and bought a solo short shifter and ES bushings.. better then before !
Yeah i see the rods when i took off the shifter boot and ****, but when i move the shifter, i see both rods moving. I just don't know if one of them is disconnected or not. How can i tell?
One end of it will be hanging freely if it fell loose. I don't think both rods should be moving. One moves to shift gears, the other is just a stabalizer i think. could be moving cause it's broken or loose. You need to get under the car.
