Annoying little squeak when clutch is pushed in and let out. On '00 Si, Help!
Old Oct 28, 2004 | 03:47 PM
Outkasted24's Avatar
Default Annoying little squeak when clutch is pushed in and let out. On '00 Si, Help!
I just sold my Integra and took over my wife's '00 Si.
The past week of driving it I've noticed an Annoying little squeak when the clutch is pushed in and let out.
I had a buddy work the clutch while I stuck my head in the engine bay and it sounds like it's coming from the front/inside of the Tranny.
What could it be?
The Clutch still grabs like it did when first purchased, but the squeak at stop lights is getting a little embarassing..
Any suggestions on how to stiffle it?
Thanks in advance
-Jeff
Old Oct 28, 2004 | 03:51 PM
BauleyCivic's Avatar
Risky Business
Default Re: Annoying little squeak when clutch is pushed in and let out. On '00 Si, Help! (Outkasted24)
The clutch fork / throwout bearing needs to be lubed...nothing you can do. All my clutches have squeaked.
Old Oct 28, 2004 | 03:52 PM
marshun's Avatar
Default Re: Annoying little squeak when clutch is pushed in and let out. On '00 Si, Help! (BauleyCivic)
is that what is? cause i swore it was the damn pedal. lol. mine has been squeeking for a while now
Old Oct 28, 2004 | 03:53 PM
Cain Marko's Avatar
Rotary Lift Specialist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic &raquo;</TD></TR><TR><TD CLASS="quote">The clutch fork / throwout bearing needs to be lubed...nothing you can do. All my clutches have squeaked.</TD></TR></TABLE>
My old cx used to sound like a creaking spring when I pushed in the clutch pedal, and it still lasted me for well over 20k miles, I think you will be just fine.
Old Oct 28, 2004 | 04:00 PM
Default Re: Annoying little squeak when clutch is pushed in and let out. On '00 Si, Help! (turtlecx92)
Thanks,
I wasn't worried about the life left in the Clutch, I just wish the squeek would go away.
Old Oct 28, 2004 | 04:06 PM
CRXB16B's Avatar
Im sure its your throw out bearing man
Old Oct 28, 2004 | 04:27 PM
ek4b18c_r's Avatar
Default Re: Annoying little squeak when clutch is pushed in and let out. On '00 Si, Help! (CRXB16B)
mine did the same thing and then just went away, so you should be fine.
Old Oct 28, 2004 | 04:30 PM
HCRX311's Avatar
Default Re: Annoying little squeak when clutch is pushed in and let out. On '00 Si, Help! (ek4b18c_r)
Mine does it to when I press it in, not when letting it out though.
Old Oct 28, 2004 | 04:38 PM
just4747's Avatar
Default Re: Annoying little squeak when clutch is pushed in and let out. On '00 Si, Help! (HCRX311)
same here..sometimes does it not too noticeably when i push it in
Old Oct 28, 2004 | 04:57 PM
H.crx-si
Guest
Posts: n/a
yeh mine does it too and it's the throwout bearing......crappy thing about mine is the tranny makes a squeaking noise when the cluth is disengaged and while driving only way to shut it up is to drive with the cluth pedal slightly being touched.
Old Oct 28, 2004 | 05:04 PM
Default Re: (H.crx-si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H.crx-si &raquo;</TD></TR><TR><TD CLASS="quote">yeh mine does it too and it's the throwout bearing......crappy thing about mine is the tranny makes a squeaking noise when the cluth is disengaged and while driving only way to shut it up is to drive with the cluth pedal slightly being touched.</TD></TR></TABLE>
Isn't there a way to adjust your clutch?
Old Oct 28, 2004 | 05:49 PM
litterbox's Avatar
I am a (Trial User) Army
Default Re: (Outkasted24)
Where's the throwout bearing located?
Old Oct 28, 2004 | 05:52 PM
Risky Business
Default Re: (litterbox)
on the mainshaft between the clutch fork and the pressure plate
Old Oct 29, 2004 | 04:30 AM
madlion's Avatar
stock civic si sucks.. upgrade it, thats what i had to do.. and get lsd when you do..
Old Oct 29, 2004 | 05:06 AM
AutoXer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Outkasted24 &raquo;</TD></TR><TR><TD CLASS="quote">I just wish the squeek would go away. </TD></TR></TABLE>
Me too. Mine's been doing it for about 50K now, sounds like a rusty spring. I only notice it usually when the car is off, so it doesn't bother me too much.
And this was what everyone said when I searched around for a solution. My girls brand new civic is starting to do the same thing.
No, because it's hydraulic.
Old Oct 29, 2004 | 06:50 AM
Happyman's Avatar
Default Re: Annoying little squeak when clutch is pushed in and let out. On '00 Si, Help! (EX_AutoXer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EX_AutoXer &raquo;</TD></TR><TR><TD CLASS="quote">
Uhm, actually you can adjust it There's an adjustment thing on the back of the clutch pedal. Can't miss it.
Old Jun 28, 2005 | 12:47 AM
jtecboi's Avatar
mines been recently doing the same on my 00 si also looking for a solution???
Old Jun 28, 2005 | 12:58 AM
96CivicBoostCoupe's Avatar
Default Re: Annoying little squeak when clutch is pushed in and let out. On '00 Si, Help! (jtecboi)
i have had the same problem with my 96 since the day i got it, just turn up the radio
Old Jun 28, 2005 | 03:30 AM
EK_GSR's Avatar
Default Re: Annoying little squeak when clutch is pushed in and let out. On '00 Si, Help! (96CivicBoostCoupe
i know this is kinda a long shot but i have a 4-puck clutch unsprung (ACT) and everytime i let go of the clutch it squeaks.... dont know just an idea....
Old Jun 28, 2005 | 05:14 AM
-Trinitron-'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96CivicBoostCoupe &raquo;</TD></TR><TR><TD CLASS="quote">just turn up the radio</TD></TR></TABLE>
That is what I do! The squeak on mine comes and goes...I think I have gotten used to it.
Old Jun 28, 2005 | 05:43 AM
mike1114's Avatar
If it squeaks only when you push in and out, it is the ball on the slave cylinder that goes into the shift fork. Grease it up and it will go away, BUT IT WILL COME BACK. Its a common honda thing.
If it makes a sqealing type noise all the time when its in gear while your driving it is your throwout bearing.
Old Jun 28, 2005 | 05:44 AM
dwnthehatch's Avatar
I had the same squeek on my itr tranny. All I had to do was lube the ball where the clutch slave cyl meets the shift fork. I put a big glob of axle grease on it and it immediately went away. Takes less than 10 minutes. Just remove the two bolts holding the slave cyl to the tranny. Pull the black rubber boot. Throw grease on the shift fork socket that comes in contact with the slave cyl, reinstall. You are done.
taimysho0
13
Aug 29, 2008 10:53 AM
EKDreamin
Apr 30, 2006 02:56 PM
NerveAgent
Honda S2000
16
Nov 17, 2005 09:56 AM
siisgood00
Feb 18, 2005 07:29 PM
