Looking for part of a sub-frame (rr suspension)
Unfortunately I do not know what this part is called.. but it connects to the suspension and is apart of the subframe. I am looking for the piece that is welded to the frame.
I need to find one for the Passenger Rear of my car. The existing was cut out by a former owner after an incident.
Also, would this part be compatible with an EG civic? I have seen what seems to be the samething on the car but am not sure if it will fit the integra 96 LS 2 dr.
ok here is the side I am looking for. The pic should give you a better idea where it is located on the subframe.
That piece that looks like p00 is the piece that I am trying to replace. The first pic that I showed you is what it is supposed to look like.
does that help? [
does that help? [
i don't know the name of that part, but if you go to your local acura parts dept. just ask them to show you the pic. or bring that pic with you. it should not be much from acura.
nope, acura doesnt sell the part. The only way I would get the piece is off of a wreck. It would have to be drilled out at the spot welds.
And my luck is that all of the wrecks that I have found in my area have been rear end damage.. so its no good.
I was hoping someone would be able to help a girl out.
haha... I just used the "I'm a girl help me out card" I know it its terrible.. but I am at my witts end trying to find it...
I have even considered if the EG civic will have the same piece on the frame that the arm goes into.. I know it does.. but will it work on the a 96 LS 2dr.??
OK found the part.
What do you think would be the best way to extract it from the donor without damaging the piece? Obviously the arm is going to have to come with it...
But do you think that drilling out the spot welds will be ok?
kay_animation
Suspension & Brakes
12
Sep 12, 2005 08:04 AM
Genedog
10
Apr 5, 2004 08:39 AM
hungsteR
Aug 30, 2002 07:56 AM
