pr3 sir wiring diagram
Old Oct 28, 2004 | 12:58 PM
teamols's Avatar
Default pr3 sir wiring diagram
i have a o2 sensor concern and a rich running condition. does anyone know where i can get a jdm civic sir honda wiring diagram? i have something similar from hasport.com and honda swap.com. but i really want an honda oem style diagram. thankyou in advance... i am running a pr3 processor on a b18c(1999).
Old Oct 28, 2004 | 01:22 PM
smart monkey's Avatar
Default Re: pr3 sir wiring diagram (teamols)
truthfully the hasport one is pretty clear. the oem one in the manual is not as easy as those other ones you have to read.
Old Oct 28, 2004 | 01:28 PM
Crx Jimmy's Avatar
are you using the sir manifold with the duel o2 sensors or a gsr one with one near the cat? if you are using the gsr one the non heated o2 sensor doesnt get hot enough back there it needs to be close to the motor to give an accurate reading, if you are using the manifold with them up front the green plug goes to the stock o2 sensor connector and the other wire directly to the ecu(i did this on my si-sir swap)
Old Oct 28, 2004 | 01:56 PM
crx_88_si's Avatar
Default Re: pr3 sir wiring diagram (Crx Jimmy)
hope this helps..
Old Oct 28, 2004 | 02:03 PM
sit220's Avatar
Default Re: pr3 sir wiring diagram (crx_88_si)
so do u do with the orange,white and blue wires
Old Oct 28, 2004 | 02:05 PM
Malgerus's Avatar
Default Re: pr3 sir wiring diagram (sit220)
http://www.hondata.com/techwiringpw0.html
Old Oct 28, 2004 | 02:43 PM
teamols's Avatar
Default Re: pr3 sir wiring diagram (Mr. S)
i have the hasport header with two 02 sensors.
Old Oct 28, 2004 | 02:46 PM
teamols's Avatar
thankyou for all replies. my ecu is virgin. i connected a lab scope and the ecu is sending the 5 millivolt reference voltage to both 02 sensors. both 02 sensors respond to being driven rich and lean . but cylinders 2 and 4 continue to run extremely rich.
Old Oct 28, 2004 | 03:13 PM
Nic's Avatar
Nic
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teamols &raquo;</TD></TR><TR><TD CLASS="quote">thankyou for all replies. my ecu is virgin. i connected a lab scope and the ecu is sending the 5 millivolt reference voltage to both 02 sensors. both 02 sensors respond to being driven rich and lean . but cylinders 2 and 4 continue to run extremely rich.</TD></TR></TABLE>
How do you know it is only 2 and 4?
Old Oct 28, 2004 | 03:43 PM
teamols's Avatar
Default Re: pr3 sir wiring diagram (stk crx)
plug are fuel fouled and blackened with carbon. other two are perfect. plugs foul in one day
Old Oct 29, 2004 | 08:21 AM
teamols's Avatar
i wonder if i'm missing a ground thats why i was looking for a oem diagram
Old Oct 29, 2004 | 10:12 AM
crx_88_si's Avatar
more pics for ya.
Old Oct 29, 2004 | 10:13 AM
crx_88_si's Avatar
sounds like maybe your o2's are installed inthe wrong cyl.
swap injectors from 2 and 4 into 1 and 3 as well. see if the fouling changes w/ injectors.
seanyreeves
Engine Management and Tuning
Oct 12, 2011 10:15 PM
.Hookedonhatch.
Dec 16, 2008 05:45 AM
miataguy
Feb 6, 2003 06:35 AM
BlkSIvic
Dec 18, 2002 05:10 AM
