What exactly is backfire?
Old Dec 20, 2001 | 03:04 PM
martilafox's Avatar
New User
Default What exactly is backfire?
Is this good or bad for the engine? What can you do to correct it ?
Old Dec 20, 2001 | 07:49 PM
Gasoline Fumes's Avatar
Default Re: What exactly is backfire? (martilafox)
Backfire is when the hot exhaust on a rich running engine meets oxygen outside of the exhaust system and ignites. Running leaner and/or using a catalytic converter will reduce backfiring. On my Wagon, more ignition advange reduces it too. I don't know if it's harmful.
Old Dec 20, 2001 | 08:14 PM
l's Avatar
l
gas in your cylinder is suppose to ignite all at once.. however if the heat from the explosion causes gas to ignite away from the flame it causes a backfire
so basically its caused by heat rather then the flame...... knock knock..
i just read that in a magazine ....
who said magazines are informative
*crossing fingers hoping this is accurate*
[Modified by CRXmadeinJapan, 5:14 AM 12/21/2001]
SIred91
18
Apr 23, 2007 04:53 PM
B00STED Si
Sep 29, 2005 08:18 PM
kriptik
Jun 3, 2005 05:45 AM
_Endless_
Aug 13, 2003 09:39 PM
eargrub
Aug 30, 2002 10:31 PM
