01 ITR Tranny - Problems with reverse.
Old Oct 28, 2004 | 10:04 AM
maxfaraday's Avatar
Default 01 ITR Tranny - Problems with reverse.
My 01 ITR has recently had problems getting into reverse. All other gears are smooth as silk, but for some reason it just wont go into reverse. The odd thing is it comes and goes. Sometimes it goes in fine, and other times its impossible. Some have told me its prob the synchro, but I didn't think reverse had one. I had the transmition flushed and that didn't seem to help. Anyone have any ideas or suggestions?
Old Oct 28, 2004 | 10:21 AM
Bbasso's Avatar
Default Re: 01 ITR Tranny - Problems with reverse. (maxfaraday)
what fluid, Honda MTF?
and if you click into 1st then revserse does it help?
Old Oct 28, 2004 | 10:32 AM
maxfaraday's Avatar
Default Re: 01 ITR Tranny - Problems with reverse. (Bbasso)
Yeah its honda MTF. Today it was really bad. I had the clutch in and ran through all the gears fine, but still couldn't get it into reverse. I eventually forced it in ... had to let off the clutch a bit and give it a little gas, which = a pretty horrible grinding noise, then it clicked in and reverse worked fine. I drove it out to get lunch, then I tried it again after driving a little bit and I could get it in much easier, but it was still tough.
Old Oct 28, 2004 | 10:35 AM
PrettyLude's Avatar
bent shift forks
Old Oct 28, 2004 | 10:39 AM
maxfaraday's Avatar
Default Re: (PrettyLude)
How does this happen? Is it easy/hard, cheap/expensive to fix ?
Old Oct 28, 2004 | 10:41 AM
ITR184's Avatar
Did you put in first and let it role foward a bit? It's a real pain in the *** when having to parallel park here in Germany.
Old Oct 28, 2004 | 10:43 AM
maxfaraday's Avatar
Default Re: 01 ITR Tranny - Problems with reverse. (Cod Sac)
Yeah I know that happens sometimes, but it isn't that. When you put it in reverse after driving for any length of time you can feel something is wrong. Feels like something is in the wrong place, its honestly feels like something is in the wrong place. Although I don't really know the interworkings of a tranny to be able to determine what the problem is.
Old Aug 18, 2009 | 11:45 PM
teggi's Avatar
im having a similar problem and also the rest of the gear get really hard and i have to bust out my ninja skills and punch da gears in
Old Aug 19, 2009 | 01:36 AM
robfrmny21's Avatar
do what some one posted early, put into 1 st let out the clutch a lil to roll, stop and try going into reverse
Old Aug 19, 2009 | 06:31 AM
srt4mike's Avatar
It sounds super simplistic, but I have driven many vehicles where you nearly have to do that every time to smoothly get in reverse. It's definitely not the end all be all solution, but it's worth trying.
ncskate
May 21, 2006 08:38 PM
redLUDEs2k1
Sep 8, 2005 05:20 PM
VTECRaZeR
May 30, 2003 11:10 PM
comptechgsr
Jan 24, 2002 06:57 AM
ashzero
Aug 10, 2001 06:25 AM
