air condition setup in a eg6
Old Oct 28, 2004 | 08:40 AM
mrpeabody's Avatar
Default air condition setup in a eg6
before i post, yes i did a search, but nothing fouund. i have the old r12 setup in my 92 for my a/c. i will be putting in a b16a swap also. my question is can i put the r134, and connect the hoses from the pump to the hard lines, and use the same a/c radiator from the r12 setup to be able to use the a/c?
Old Oct 28, 2004 | 09:39 AM
PrettyLude's Avatar
yes you can do it, but u will also need a p54 del sol ac bracket
Old Oct 28, 2004 | 06:07 PM
mrpeabody's Avatar
Default Re: (PrettyLude)
kool. so as far as everything goes, i'll need to upgrade if you want to call it, r134 pump(b or d series), a/c bracket(b or d series), r134 hoses(high/low), Radiator(orig r12 unit), and the r134 chemical. if i missed anything let me know...
Old Oct 29, 2004 | 04:59 AM
mrpeabody's Avatar
bmp
Old Oct 29, 2004 | 05:09 AM
JimBlake's Avatar
Default Re: (mrpeabody)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrpeabody &raquo;</TD></TR><TR><TD CLASS="quote">... if i missed anything let me know...</TD></TR></TABLE>Receiver/dryer, & don't forget cleaning & evacuating.
The oil from the R12 isn't good in the R134a system, so you have to clean out the insides of the evaporator, condensor, hoses, whatever. The dessicant in the receiver dryer isn't so easy to clean & dry, so most people replace it. Leftover oil from the R12 can keep it from cooling as much as it should.
Removing ALL the air & moisture from the system is important. That's why you run a vacuum pump on it for awhile before putting in the R134a.
Old Oct 29, 2004 | 05:15 AM
acy76's Avatar
Default Re: (JimBlake)
You could also charge with Enviro-Safe -- no purging/vaccum pulling needed, compatible with the R12 and R134 systems and their chemicals, better for your system and for the environment than either. I use it and it works great. Cheaper than converting if you've got an older car.
http://www.es-refrigerants.com/
crazyguy
12
Jun 10, 2007 01:45 PM
lsjon
Mid-Atlantic (Sales)
May 3, 2007 01:05 PM
boostmywankle
Aug 2, 2006 12:25 PM
axtran
Apr 30, 2006 09:39 PM
Mentat Ghola
May 14, 2005 05:48 AM
