What motor mounts is everyone using???
Old Oct 28, 2004 | 07:04 AM
Death_to_Thieves's Avatar
Default What motor mounts is everyone using???
What motor mounts is everyone using??? Stock or anything like aftermarket inserts? all my motor mounts are shot and want to know if I should stick with OEM or go with something better. I found out all my motor mounts were shot. I kept breaking my driver side axle like every month for like 3 months. Turned out I need new mounts. any recommendations? setup is in my sig. Thanks guys
Old Oct 28, 2004 | 08:44 AM
H.A.R.T B18C1EG6's Avatar
Default Re: What motor mounts is everyone using??? (8000KReV)
Hasport~
Old Oct 28, 2004 | 08:54 AM
BigPlansNoMoney's Avatar
Default Re: What motor mounts is everyone using??? (H.A.R.T B18C1EG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H.A.R.T B18C1EG6 &raquo;</TD></TR><TR><TD CLASS="quote">Hasport~</TD></TR></TABLE>
Old Oct 28, 2004 | 09:37 AM
PrettyLude's Avatar
one more vote for hasport
Old Oct 28, 2004 | 10:19 AM
Default Re: (PrettyLude)
Im sure you guys have swaps though so you need hasport mounts right?? I have a 92 integra GSR that is not in need of Hasport mounts for a swap. I pretty much just want to know if there are any aftermarket mounts that are worth buying and that are better than OEM. I have heard of inserts or soemthing but am not too sure as to how these work or the quality of them. Do you just recommend getting OEM mounts or what?
Old Oct 28, 2004 | 11:13 AM
type-t's Avatar
Default Re: (8000KReV)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 8000KReV &raquo;</TD></TR><TR><TD CLASS="quote">Im sure you guys have swaps though so you need hasport mounts right?? I have a 92 integra GSR that is not in need of Hasport mounts for a swap. I pretty much just want to know if there are any aftermarket mounts that are worth buying and that are better than OEM. I have heard of inserts or soemthing but am not too sure as to how these work or the quality of them. Do you just recommend getting OEM mounts or what?</TD></TR></TABLE>
i've seen these inserts on ebay..and i was also wondering how good they..do you really get more horsepower to the wheel? no assumption please..i can assume all day on my own...thanks
Old Oct 28, 2004 | 11:25 AM
spoonek9's Avatar
Default Re: (type-t)
Spoon makes mounts that are a little stiffer than OEM. They make them to control the engine swaying in the car when cornering. They don't have all the vibration assocaited with the inserts or solid mounts.
Too bad they don't make them for the DA
Old Oct 28, 2004 | 12:33 PM
type-t's Avatar
Default Re: (spoonek9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoonek9 &raquo;</TD></TR><TR><TD CLASS="quote">Spoon makes mounts that are a little stiffer than OEM. They make them to control the engine swaying in the car when cornering. They don't have all the vibration assocaited with the inserts or solid mounts.
Too bad they don't make them for the DA</TD></TR></TABLE>
what is the website for these mount inserts...and does anyone know about the hp increase when using them
Old Oct 28, 2004 | 04:42 PM
RedSI93's Avatar
Yes as far as swap mounts, hasport, but in your case i would get some energy suspension inserts, I had them in my single cam and it was like a night and day diffrence. What that guy said about the spoon mounts could also be an option, but i dont know anything about them.
ES inserts getsa from me
juanhda9
25
Feb 2, 2012 07:56 PM
hard_boiled_EG
Dec 10, 2009 08:39 PM
D16SohcVtec
Aug 12, 2008 08:03 AM
RidinStock
Feb 4, 2006 09:13 AM
Dumped DB2
Aug 2, 2005 11:00 AM
