Avid motor mounts - everything in car shakes
Alright well I have a 1992 civic si hatch with a Gsr swap built head n other things but it came with avid solid motor mounts I was told thing is there stiff as Hell everything in car shakes even loose change in door coin pockets annoys the Hell out of me so I'm looking for something better for daily driving and not stiff as Hell iv rode in a car with innovative mounts very much like stock any mounds you guys would reccomend for my car?
Re: motor mounts?
Just run some stock GSR mounts, and get a brace from NRG. All the poly mounts buzz like crazy, and are "stiff as hell" as you put it. The NRG brace will take away alot of the movement from the motor and actually not introduce much vibration. Try it. You can even get the mounts at the junkyard for very little if you're on a budget.
Re: motor mounts?
Alright so mounts I picked up were for a da integra wrong ones which sucks but took them Back. So I was reading around and some ppl say that itr motor mounts are a bit stronger then Gsr mounts is that true n if so would they fit my car?
Re: motor mounts?
They may be pretty hard to find used, and likey expensive.
If you use stock mounts, your engine will be sitting a little higher then aftermarket and cause a "pimple" in the hood, just a warning for you
Well for b series engines in a non b car..
The Grumpiest
Re: motor mounts?
I don't think Hardrace makes mount kits for swaps do they? Otherwise, as a 5 year user, I would say get them without question. Hard rubber over Poly any day.
Ek Forever y0!
Re: motor mounts?
As far as I understand, they are swap mounts.
http://www.buyhardrace.com/product/h...ivic-ek_4.html
Damn, now I'm not sure.
The Grumpiest
Re: motor mounts?
I don't see the difference. A 99-00 Si B-series mounts should work for a 96-00 civic with a d-series.
Seagull Management
Re: motor mounts?
They're the same, but the OP has a '92 hatch. OP buy mounts for a '94 - '01 Integra. If you use integra torque mounts you'll need to cut a little square tab off the bottom of the frame rails for them to lay flat.
Re: motor mounts?
So if i wanted to get the hardrace I would need the integra ones? Did resarch n ppl really like these mounts I'm thinking of buying
Ek Forever y0!
Re: motor mounts?
The description for 96-00 civics doesn't mentioned the type of swap.
Re: Avid motor mounts - everything in car shakes
Well I didn't go with the hardrace because I read somewhere there just as good as stock n don't want to wait on shipping n have wrong fitments so just got stock itr passanger and drivers mount stuck with the avid rear torque mounts also have avid front torque mount inserts n I like it way better don't have any shake almost as if I had a d series n I went with itr mounts because I have an itr.
Ek Forever y0!
Seagull Management
How's the vibration marc? close to stock in that regard?
The Grumpiest
It's near stock but also stiffer. It's hard to explain really. I had an NRG engine brace that transferred more vibration than these do. Once I installed these I had no need for it any more.
So what ones would fit a b18c5 my friend wants to try them out on his car he has the same issue I did he has it in a eg also
