del sol won't start please help
Old Oct 28, 2004 | 01:45 AM
honda eg9
Guest
Posts: n/a
Default del sol won't start please help
Hi I'm new here and need some help, my friends del sol won't start it has a b20 with a itr type r head the car has been sitting for about 6 months started every other week and run for about 15-20 minutes well one day the battery died and we did'nt start it for about a month, when we got another battery it will crank strong but not start I checked all the fuses,wires,plugs,dist, fuel pump, basically everything I could think of and my other friend checked the alarm to make sure that was'nt the problem we even used a remote starter button just to see if it had spark (it does) and to see if it would start that way (it did'nt)
Please help
Old Oct 28, 2004 | 03:22 AM
murmur9's Avatar
Default Re: del sol won't start please help (honda eg9)
forget to add fuel stabalizer ? lol i donno, you got me..i was thinking dixxy wheni read the titla...but you already checked. fuel line somewhere fucked up,clogged?
Old Oct 28, 2004 | 03:34 AM
honda eg9
Guest
Posts: n/a
Default Re: del sol won't start please help (murmur9)
lol yeah the first thing I though the car was out of gas so we got 5 gal of 92octane and put it in. I checked the lines took off the return line and turned the ignition on everything seems to be flowing good
Old Oct 28, 2004 | 04:32 AM
boosted_dc2's Avatar
fuel, spark and compression is what is needed. you have spark, so check fuel. check your main relay. check your ecu connections (you never know), and also pull the valve cover and see if the timing best has broken or slipped some teeth.
Landon
Old Oct 28, 2004 | 04:52 AM
honda eg9
Guest
Posts: n/a
Default Re: del sol won't start please help (boosted_dc2)
timing belt is good compression is good across all cylinders, I guess I'll check the main relay. Heard alot of people having problems with those things lately I hope thats the problem
Old Oct 28, 2004 | 05:11 PM
honda eg9
Guest
Posts: n/a
idk main relay did'nt seem to be the problem I guess I'll try with my ecu.
Anybody can think of anything please lmk
Thanks
nicoloolivotto
May 4, 2017 06:00 PM
mooney8289
13
Aug 3, 2013 12:54 AM
s2knjax
Feb 8, 2010 12:00 PM
Dominicanstylz02
Jul 25, 2006 04:25 AM
