del sol won't start please help
Guest
Posts: n/a
Hi I'm new here and need some help, my friends del sol won't start it has a b20 with a itr type r head the car has been sitting for about 6 months started every other week and run for about 15-20 minutes well one day the battery died and we did'nt start it for about a month, when we got another battery it will crank strong but not start I checked all the fuses,wires,plugs,dist, fuel pump, basically everything I could think of and my other friend checked the alarm to make sure that was'nt the problem we even used a remote starter button just to see if it had spark (it does) and to see if it would start that way (it did'nt)
Please help
Please help
Re: del sol won't start please help (honda eg9)
forget to add fuel stabalizer ? lol i donno, you got me..i was thinking dixxy wheni read the titla...but you already checked. fuel line somewhere fucked up,clogged?
Guest
Posts: n/a
Re: del sol won't start please help (murmur9)
lol yeah the first thing I though the car was out of gas so we got 5 gal of 92octane and put it in. I checked the lines took off the return line and turned the ignition on everything seems to be flowing good
fuel, spark and compression is what is needed. you have spark, so check fuel. check your main relay. check your ecu connections (you never know), and also pull the valve cover and see if the timing best has broken or slipped some teeth.
Landon
Landon
