Speedometer sticking. any ideas?
Old Oct 27, 2004 | 08:48 PM
imadigitalgod's Avatar
Default Speedometer sticking. any ideas?
Lately my 99 EX civic(4dr), the speedometer has been sticking up until 20mph then it jumps to 0 to whatever speed im going. last saturday i was going to work and the meter didnt work at all no matter what speed i was going but when i got off 8 hours later, it worked fine(it only jumpts from 0-20 about 1/3 of hte time). does anyone have any ideas whats wrong? do i need to buy a new assembly for the speed. ?
Old Oct 27, 2004 | 08:50 PM
Ricey McRicerton's Avatar
Default Re: Speedometer sticking. any ideas? (imadigitalgod)
Sounds to me like either your guage cluster is sticking under 20mph or your VSS (Vehicle Speed Sensor) is starting to go out. The VSS is on the top rear of your transmission. You can try to make sure that all of the connections on the plug to it are still good. The only thing that would lead me to believe that it is your guage cluster is that it's only doing it up to 20 mph. A faulty speed sensor usually jumps around and can go completely dead at times.
Old Oct 27, 2004 | 09:11 PM
Default Re: Speedometer sticking. any ideas? (Ricey McRicerton)
how much would a new speed sensor cost and is it hard to replace? the reason y ia sk is that last saturday it did go dead and didnt work until i got off work
Old Oct 27, 2004 | 09:13 PM
E dwinbon G's Avatar
are you throwing any codes for VSS? or have you messed with the speedo before? like indiglo gauges?
Old Oct 27, 2004 | 09:23 PM
Default Re: Speedometer sticking. any ideas? (E dwinbon G)
no i just got the car a few weeks ago. the only things i ahve done is the stereo stuff and thats all. how would i check the codes on this car? i know what codes are(i did them on my nissan altima, it was totaled so i got a civic) i jsu dont know how to ckeck them on the 99 civic right now. the check engine light doesnt come on tho
Old Oct 30, 2004 | 02:32 PM
kysard's Avatar
mine does the same thing, I wasted $100 on a VSS, it didn't help at all. Guage clusters are hard to find and expensive. You would think someone could repair it
Old Oct 30, 2004 | 08:38 PM
Default Re: Speedometer sticking. any ideas? (kysard)
how much would a guge cluster be brand new? woudl a junkyard be a good place to findone?
Old Oct 31, 2004 | 02:21 AM
Evolution-93-Ex's Avatar
From: Your mommas bed, that might be true too ..., So Cali, USA
Default Re: Speedometer sticking. any ideas? (civic_rice)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by E dwinbon G &raquo;</TD></TR><TR><TD CLASS="quote">are you throwing any codes for VSS? or have you messed with the speedo before? like indiglo gauges?</TD></TR></TABLE>
I put indiglos in my cluster awhile ago could that be a reason why mines doesnt work ???
Old Oct 31, 2004 | 02:57 AM
dantastic's Avatar
DX clusters (without tach) are usually really cheap and easy to come by. the speedo will swap over into your EX cluster.
daviss22
Apr 22, 2012 09:19 AM
ryrex02
Dec 7, 2010 05:53 PM
aziaticvang
Jan 13, 2008 06:35 PM
aws140
Aug 17, 2005 07:08 PM
slow4dr
Dec 27, 2004 07:19 AM
