Which block to go with my d16z6 head?
Old Oct 27, 2004 | 08:13 PM
jadugartir's Avatar
Default Which block to go with my d16z6 head?
I am trying to find out what block options are and maybe a little info about them... I am building a new motor to swap into my dx hatch and i want the best available block to go with my z6 SOHC VTEC head. I got the head, with intake manifold and distributor already mounted but im about to start taking it apart and cleaning it and later port and polished. Basically im looking for some useful reading or some opinions on what direction to take with my swap.
Old Oct 27, 2004 | 08:15 PM
Gumbey75's Avatar
Default Re: Which block to go with my d16z6 head? (jadugartir)
go with the d16 from either the si crx's/ ex 16's/ or del sol si d16. all good platforms.
Old Oct 27, 2004 | 08:16 PM
mrspeaker's Avatar
Is the block for N/A or forced induction...
Old Oct 27, 2004 | 08:25 PM
jadugartir's Avatar
Right now i dont have the funds for forced induction. I just want a clean *** N/A engine most likely, although i wouldnt mind some future potential. What are the full names of the blocks you are talking about, so i can do more research. any links on this would be appreciated as well. Really i want to know my options and their advantages and disadvantages.
Old Oct 27, 2004 | 08:38 PM
jadugartir's Avatar
Do i have to go OBD1 or OBD2 or something? right now i have everything for the head swap but the ECU. so im still undecided on the direction of my swap with my block and ECU. What would you guys match to that head for a nice strong N/A motor, partly because i dont know what wiring is compatible with what.
Old Oct 27, 2004 | 08:55 PM
mrspeaker's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jadugartir &raquo;</TD></TR><TR><TD CLASS="quote">Do i have to go OBD1 or OBD2 or something? right now i have everything for the head swap but the ECU. so im still undecided on the direction of my swap with my block and ECU. What would you guys match to that head for a nice strong N/A motor, partly because i dont know what wiring is compatible with what.</TD></TR></TABLE>
Best thing to do is get a obd0-obd1 jumper harness.and use an obd1 ecu(p28 for z6)
And you have a DX so MPFI swap is needed..
Old Oct 27, 2004 | 09:41 PM
jadugartir's Avatar
Default Re: Which block to go with my d16z6 head? (Mrspeaker)
K im gonna use the d16z6 block, p28 ecu, then what wiring needs to be done? dont i just need the straight harness from the 92-95 z6? That is what we call going OBD1, or am i mistaken?
Old Oct 28, 2004 | 05:24 AM
mrspeaker's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jadugartir &raquo;</TD></TR><TR><TD CLASS="quote">K im gonna use the d16z6 block, p28 ecu, then what wiring needs to be done? dont i just need the straight harness from the 92-95 z6? That is what we call going OBD1, or am i mistaken?</TD></TR></TABLE>
...Use your DX harness and just buy a obd1 conversion jumper harness from "blown90hatch" or where ever and wire it in...Thats the easy way..
Old Oct 28, 2004 | 05:46 AM
crx_88_si's Avatar
stay away from ANY d16y8/y7 motor. the oil pumps are poop in the "y" series motors. even if u replace the oil pump, its still garbage.
i'd use a d16z6 block. d16a6 as second choice. but thats just me.
Old Oct 28, 2004 | 06:54 AM
Brownjd's Avatar
Default Re: (crx_88_si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si &raquo;</TD></TR><TR><TD CLASS="quote">i'd use a d16z6 block. d16a6 as second choice. but thats just me.</TD></TR></TABLE>
it's not just you anymore, i second that
Old Oct 28, 2004 | 07:05 AM
4drEF's Avatar
Keyboard Humorist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si &raquo;</TD></TR><TR><TD CLASS="quote">stay away from ANY d16y8/y7 motor. the oil pumps are poop in the "y" series motors. even if u replace the oil pump, its still garbage.
Could use a Z6 pump and relocate the oil dip stick somehow. ?!?!?
Old Oct 28, 2004 | 08:41 AM
turboZChatch's Avatar
Default Re: (4drEF)
Use the z6 and if you cant find one use an a6 just dont use the y or the 1.5 blocks
Old Oct 28, 2004 | 09:58 AM
ceLtic's Avatar
N/A wh0re!
a d16z6 block.
Old Oct 29, 2004 | 10:14 AM
mannyman's Avatar
El Veterano de Sur Califas
Default Re: (turboZChatch)
wow.. are the y blocks that bad. Hmmm, I may start looking for an a6 if thats the case.
manny
95ccoupe
Oct 12, 2006 03:53 PM
HONDA92HATCH
Aug 30, 2004 02:44 PM
fire7882
Mar 4, 2003 05:37 AM
e_SolSi
Sep 24, 2002 09:31 AM
