Installed clutch and grinds in second gear now...help???
Old Oct 27, 2004 | 05:28 PM
GIANT's Avatar
Default Installed clutch and grinds in second gear now...help???
I just installed a new clutch and flywheel and now my tranny grinds in second gear when I power shift at high rpms. When I shift normal it does fine though. All other gears are fine. Any info will help...Thanks
Old Oct 27, 2004 | 06:09 PM
drdisco69's Avatar
Default Re: Installed clutch and grinds in second gear now...help??? (GIANT)
Stop power shifting.
Old Oct 27, 2004 | 07:43 PM
GIANT's Avatar
hahaaha...have to shift hard. "Drive it like you stole it!!!"
Old Oct 27, 2004 | 08:09 PM
Billy Blaze's Avatar
When you removed the trans did you just un-bolt the slave cylinder, and the hydrolic line, or did you just unbolt the slave and let it hang leaving the hydrolic line conected? aka (the right way to do it)
If you opened the fluid line when you put it together you have to bleed the clutch. If you have already you may need to bleed it more.
If it's grinding going into gear either the clutch is still touching the fly wheel, or you have a bad second gear syncro.
Old Oct 27, 2004 | 08:14 PM
rev-speed's Avatar
did u lose one of the bolts 4 the slave cylinder and not put it back on?
99hondadx
Feb 10, 2017 05:35 AM
93dx
Feb 3, 2005 02:40 PM
4thgenlude
Oct 5, 2004 09:30 PM
91_2.0_Si
May 20, 2004 07:05 PM
B18cteg
Jul 3, 2003 10:18 AM
