dc5 itr muffler on dc2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by an2ny888 »</TD></TR><TR><TD CLASS="quote">just picked up a used itr dc5 muffler. anybody put this on their ITR yet? any gains and differences in sound? </TD></TR></TABLE>
will it fit?
will it fit?
not bolt on, but it will fit with some minor modding. it also has a bypass valve inside, so i'm hoping it will give better low end torque
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by an2ny888 »</TD></TR><TR><TD CLASS="quote">not bolt on, but it will fit with some minor modding. it also has a bypass valve inside, so i'm hoping it will give better low end torque</TD></TR></TABLE>
from my memory the bypass valve is there to reduce sound, not do give more torque
why even put a dc5 muffler on there anyway? if you are going to mod it to fit your dc2, why don't you mod the dc2 one?
Just buy an aftermarket exhaust. I don't see the point in putting money into another stock exhaust, that probably won't gain as much as an aftermarket. **** it, run open headers!
it'd probably be beneficial if you modded the piping so there were no bottlenecks, but other than that, i see no reason to try to put a stock exhaust on.
actually i'm currently using a mugen twin loop cat back. just wanted to try the dc5 muffler as an experiment, and i will be modding the stock b pipe if i ever actually go through with this
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by an2ny888 »</TD></TR><TR><TD CLASS="quote">actually i'm currently using a mugen twin loop cat back. just wanted to try the dc5 muffler as an experiment, and i will be modding the stock b pipe if i ever actually go through with this</TD></TR></TABLE>
I guess you are really bored and money to burn, good luck.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FATninja19 »</TD></TR><TR><TD CLASS="quote">How's the bypass valve work? </TD></TR></TABLE>
https://honda-tech.com/zerothread?id=1025325
1sic95accord
Sep 16, 2018 09:15 PM
Aespooncivic
Mar 23, 2005 09:50 PM
CHiNkStEr
Mar 1, 2005 12:12 PM
