Which spark plugs?
Old Oct 27, 2004 | 05:34 AM
Chiller's Avatar
Default Which spark plugs?
I've searched and all I've gotten was part numbers...
I've read that the ITRs run irridium plugs and that the copper ones conduct better electricity but have a lower life span. Correct?
Ok, now here's the question. If I were to go with the copper plugs, which car would have these stock? Reason I'm asking is that the part numbers aren't the same here in Europe. So I'll have to tell Honda which car the plugs come off of.
Thanks for your help.
Old Oct 27, 2004 | 06:05 AM
DutchITR1689's Avatar
Default Re: Which spark plugs? (Chiller)
https://honda-tech.com/zerothread?id=986824
If you really want the copper plug, get the B16A plug, but in heatrange 7 for B18C6.
BTW. In a platinum plug, the core is still copper, only the tip (0.1 mm) is platinum. And electrical conductivity is not the only thing that is important for a spark plug.
Modified by DutchITR1689 at 4:15 PM 10/27/2004
Old Oct 27, 2004 | 09:54 AM
Chiller's Avatar
Thanks a lot for the link... I guess searching owned me on that one.
So, as I gather I should get the NGK irridiums. Is that the stock ITR plug? What car uses those plugs stock that I can use?
Old Oct 27, 2004 | 12:40 PM
B2FiNiTY's Avatar
Default Re: (Chiller)
Stock plugs are platinum.
Gap 6, heat range 1.1
Old Oct 27, 2004 | 02:15 PM
nuro's Avatar
Default Re: (B2FiNiTY)
no one has answered his question even if you have all provided useful information.
off of what car can you find the iridium plugs that he needs?
Old Oct 27, 2004 | 02:17 PM
Default Re: (nuro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nuro &raquo;</TD></TR><TR><TD CLASS="quote">no one has answered his question even if you have all provided useful information.
That's because the answer is in the link I gave. Did you even read it? Yes, read the WHOLE thread.
Old Oct 27, 2004 | 03:11 PM
Chiller's Avatar
I read the whole thread and we don't have the RSX type S in europe as you know very well... Does this mean that I should take the Civic Type R plugs? Where do you get your plugs from? Thanks.
Old Oct 27, 2004 | 03:36 PM
ITR184's Avatar
http://www.densoiridium.com/fi...earch
denso IK20 gap .044. you should be able to find them on several websites. In case you haven't used Iridium plugs, they allready come gaped. Do not try and gap them you will mess up the electrode. Get you a set of Magnacore wires to go with them and you will notice a crisper throtle response.
Old Oct 27, 2004 | 03:54 PM
Chiller's Avatar
Thanks for the help.
Old Oct 27, 2004 | 04:30 PM
ITR184's Avatar
If you have B18C6 You might want to check further into that.
The platinum plugs in NGK are C5= PFR6G-11, C6=PFR7G-11.
Old Oct 27, 2004 | 10:23 PM
Chiller's Avatar
So as Ive gathered this is how it works:
For the B18C6 I should get either the Denso IK22 or the IFR7G-11.... Are both of these spark plugs pregapped? Also where can I get these in europe?
Old Oct 28, 2004 | 02:16 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiller &raquo;</TD></TR><TR><TD CLASS="quote">Does this mean that I should take the Civic Type R plugs? Where do you get your plugs from? Thanks.</TD></TR></TABLE>
Yes, the engines of the CTR and the RSX-S are almost the same.
You should be able to get it at any car parts store.
Old Oct 28, 2004 | 02:18 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiller &raquo;</TD></TR><TR><TD CLASS="quote">For the B18C6 I should get either the Denso IK22 or the IFR7G-11.... Are both of these spark plugs pregapped? Also where can I get these in europe? </TD></TR></TABLE>
For NGK: Yes, -11 means 1.1 mm gap.
Denso: I don't know. Probably pregapped at 0.8 mm. Not sure.
You should be able to get these at a good car parts store or Honda dealer for the CTR plug (= most likely more expensive).
Old Oct 28, 2004 | 02:47 AM
ITR184's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiller &raquo;</TD></TR><TR><TD CLASS="quote">So as Ive gathered this is how it works:
Here is a site I found in the UK. I never used them before. They also have a 10%rebate when you buy the denso Iridium and Magnacore wires together.
http://www.spark-plugs.co.uk/index.htm
Old Oct 28, 2004 | 04:54 AM
Chiller's Avatar
Thanks you guys!!! You've helped me a lot.
Will changing the spark plug wires really change the performance? I already bought the OEM ITR wires for when I do the service, is it worth returning them and getting these Magnacore ones?
Old Oct 28, 2004 | 07:49 AM
Chiller's Avatar
i went ahead and ordered the CTR spark plugs ill post up once theyre in and let you guys know.
anyone know what size socket ill need for the plugs?
Old Oct 28, 2004 | 02:45 PM
ITR184's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiller &raquo;</TD></TR><TR><TD CLASS="quote">Thanks you guys!!! You've helped me a lot.
Will changing the spark plug wires really change the performance? I already bought the OEM ITR wires for when I do the service, is it worth returning them and getting these Magnacore ones?</TD></TR></TABLE>
I only had 12,000 miles on my OEM wires, and noticed a crisper throtle response with the Magnacore wires. Actually that upgrade with the Iridium plugs, and Magnacore wires was impressive for what little money I spent on it.
Old Oct 29, 2004 | 04:42 AM
Chiller's Avatar
For the moment Ill ride like this and will change wires on my next oil change.
Old Oct 29, 2004 | 05:05 AM
Willard's Avatar
I like the fit and finish of the OEM wires.
Old Oct 29, 2004 | 05:11 AM
iperez's Avatar
Here's my "***-dyno" review on the plugs ..
I have Denso Iridiums (IK20) with MSD 8.5 wires.. These are by far the best performing plugs I've used. I've used the OEM plugs, Bosch +2 plugs, NGK Iridiums, NGK OEM replacement plugs..
The denso's give the car more torque that you can actually feel. Shifting gears is actually fun
NGK Iridiums were a lot cheaper than the Denso's and felt pretty much the same.
Old Oct 29, 2004 | 08:18 AM
white rocket's Avatar
Default Re: (iperez)
I'm getting the Spoon wires and NGK Iridiums put on, as well as my T1R catback, tomorrow.
&lt;----who is a sucker for the bling.
slammedda9
Jul 5, 2008 01:55 PM
unknown2
Jun 12, 2004 09:34 AM
Casey
Mar 19, 2002 07:00 PM
mattmw88
Feb 22, 2002 07:54 AM
