NOT RUNNNING OR NOTHING
Old Oct 26, 2004 | 08:38 PM
StewdaddySiRII's Avatar
Default NOT RUNNNING OR NOTHING
Hey I coming up to a stop light and my car just dies.. Try to start nothing happend... So i PUsh it backto get a closer look.. See that my dis is puttin off no spark. so i got a new coil and ignitor.... Still nothing.. my distirbotor is not siesed and turns fine... I have an obd 2 car with a obd1 Motor And the dis hard pinned to the ECU..((((MY ECU uses A jumper harness))) I also noticed that when i go to crank the car over the fuel is not kickin on.... Could my ECU be Shot?? OR what help me here... I'm so lost right now.. Not to mention pissed off like ****...
Old Oct 26, 2004 | 08:49 PM
drdisco69's Avatar
Default Re: NOT RUNNNING OR NOTHING (StewdaddySiRII)
If the sensors in the distributor go bad, or the wiring breaks, it can cause things like that. Do you get any check engine lights? If not it could be the ecu, worst case...
Old Oct 26, 2004 | 09:20 PM
rev-speed's Avatar
first check all the fuse
Old Oct 27, 2004 | 06:30 AM
Where is the main Relay @.....I was told this was my problem. and if it is... Can i gank one from n e civic or does it have to be from a 99-00 civic or can it be from a 96-98 92-95.....
Modified by StewdaddySiRII at 10:57 AM 10/27/2004
Old Oct 27, 2004 | 03:18 PM
PrettyLude's Avatar
its underneath the driver side panel, held on by two 10 mm bolts
dnxracer
Jun 17, 2012 10:53 AM
h22blklude92
Aug 27, 2007 06:24 AM
jerdizzle14
Feb 4, 2007 01:07 PM
HOND PWR
Nov 15, 2004 08:37 AM
