DSM 450's Injector Clip Wiring
Old Oct 26, 2004 | 11:29 AM
Excelerate's Avatar
Default DSM 450's Injector Clip Wiring
Alright, I have the DSM 450's installed, but I still need to do the wiring. On the DSM Injector Clips, which wire is the signal wire? and which is the constant? And then what is the corresponding wire on my car, 99 Accord i4? Thanks.
Old Oct 26, 2004 | 12:33 PM
Excelerate's Avatar
Default Re: DSM 450's Injector Clip Wiring (Excelerate)
Any help would be appreciated.
Old Oct 26, 2004 | 01:11 PM
tgreaves's Avatar
The constant wire is the positive side.. You can tell them because that are all the same color wire for all the injectors..
Old Oct 27, 2004 | 07:17 AM
Excelerate's Avatar
Default Re: DSM 450's Injector Clip Wiring (tgreaves)
Yes, the constant wire on the injector side is the yellow/black wire from my Accord. But what wire do you tap into on the DSM injector clip side? On the injector clip, what wire is constant and what is signal?
Old Oct 27, 2004 | 07:20 AM
tgreaves's Avatar
Im not sure I understand your question then.. The black/yellow wires on the injector plugs are the common wires + and the other color wires are the signal -..
Old Oct 27, 2004 | 08:18 AM
BME1986's Avatar
On each clip there will be 2 wires(obviously). The wire that is the same color on all four clips will be the constant(positive) side. The other wire will be a different color on all four clips. This is the negative side. Hope this helps.
Old Oct 27, 2004 | 10:02 AM
Excelerate's Avatar
Default Re: DSM 450's Injector Clip Wiring (BME1986)
Thanks.
95dc2teg
Dec 15, 2008 08:47 PM
hyper em1
Jan 31, 2007 09:46 PM
Tippyman
14
Mar 27, 2006 08:55 PM
Mr. Vapor
Apr 27, 2005 12:29 PM
Eluzion
Sep 11, 2004 11:36 PM
