what engines would fit
what engines would fit into a 93 accord and trannys that i would not have to do too much work with and changing a lot of stuff ?? would a 94 - 97 tranny and engine fit would i have to change the axles ? the ecu and what else ? or do you all have a better sugestion and no i do not have money for h22 i wish .
yes, the 94-97 motors and trannies will all fit...but there isn't much of a point since the only motor for the 94-97 accords that is more powerful is the f22b1, in which case you can just swap your head for the sohc vtec head and have the exact same motor...
yeah an f22 or even an f23 will fit, all the same, just remember if you do get a different engine make sure the ecu you have matches, for example a vtec engine will not work with a non vtec ecu, also remember about changes if you do get an obd2 f23, ecu will have to be obd2 unless you convert it down to odb1 and run with a obd1 ecu, tranny wise all f and h series trannyz will fit, My personal favorites would be the h23 tranny out of the prelude si or the h22 tranny with lsd. And don't get an h22 even if you do ever have the money, a f series engine is good for boost and with the money it takes to get a h22 you can have a nicely boosted "F", and kill an h22's all day
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nick H »</TD></TR><TR><TD CLASS="quote">yes, the 94-97 motors and trannies will all fit...but there isn't much of a point since the only motor for the 94-97 accords that is more powerful is the f22b1, in which case you can just swap your head for the sohc vtec head and have the exact same motor...</TD></TR></TABLE>
Do you know of anywhere to buy the necessary parts for the head swap and maybe some instructions on how to do it?? Sorry, I didn't search, but I'm excited cause I didnt think you could make an A1 into a B1. Any info would be great! Thanks!
er.. i dont know where you can find the parts themselves, but any info on whatelse you would be planning to do the engine and whatnot would be helpfull in advising you on the best option (turbo, na etc.)
big_dong861
21
Oct 25, 2007 05:25 AM
