my car is broken!!
Old Oct 26, 2004 | 04:16 AM
sickboysince81's Avatar
Default my car is broken!!
1998 acura integra b18b1 5spd.
well, i checked my code and its showing a 67.(catalyst not up to standards). guess its time to get a hi flow cat but before i get one anyone know a way to check the sencor? i know you hit it with a volt meter when its cold and again when its hot but not sure what the volts should be at, should be in a chiltons or haynes repair book if anyones got one id apreciate it.
my car is off to get a new clutch tomorrow, not an upgrade or anything im just an ******* probably burned it up. i dont have the tools or time to tackle a clutch and this would be a first attempt on a fwd car.heres what its doing.
-wont select/shift into gear when the engine is running.
-can select gears when engine is off.
-clutch pedel feels spongy and kinda shakes a little.
-if you try to put it in reverse when its running it just grinds.
-if you leave it in gear and try and start it with the clutch pedel depressed it makes the car jump like if ya didnt have the clutch down at all.
its my clutch right? i suck at diagnosing stuff but im pretty damn sure its my clutch.
hmm...screw paying rent. i need to drive.
mr abstract
Nov 27, 2006 10:56 AM
dexy
Jan 11, 2005 09:53 AM
dexy
Jan 10, 2005 10:17 AM
Adampops
Jul 24, 2002 09:24 AM
