oil on my plugs
Old Oct 25, 2004 | 02:29 PM
djvtec5's Avatar
Default oil on my plugs
i went to change out my spark plugs and it was dreched in ooil what could be the prob.... and is it bad
Old Oct 25, 2004 | 02:39 PM
Kyles ej1's Avatar
Default Re: oil on my plugs (djvtec5)
bad valve seals
Old Oct 25, 2004 | 02:40 PM
Echo7847's Avatar
Check the tube seals on the valve cover first.
Old Oct 25, 2004 | 02:56 PM
djvtec5's Avatar
Default Re: oil on my plugs (Echo7847)
you think that what it is
should i go get another gasket about how much do they run
Old Oct 25, 2004 | 03:10 PM
Archidictus's Avatar
Unceasing Measure
Let's discuss your vehicle and motor first, shall we? Are you turbo or supercharged? Did you recently replace gaskets on your head or valve cover?
Old Oct 25, 2004 | 03:15 PM
_Spugen_'s Avatar
I think its somewhere around 30 bucks for new gasket and valve seals...
Old Oct 25, 2004 | 03:16 PM
Leviata-N's Avatar
Default Re: oil on my plugs (Archidictus)
The Valves Seals
And or the Piston rings
No it is not too bad, but take it to the garage before the police do it for you, for throw a lot of smoke
Old Oct 25, 2004 | 03:34 PM
00Red_SiR's Avatar
All Motor Mentor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Echo7847 &raquo;</TD></TR><TR><TD CLASS="quote">Check the tube seals on the valve cover first.</TD></TR></TABLE>
Exactly it's more than likely your spark plug tube/valvecover seals that need to be replaced, they tend to leak on Hondas.
black0hatch
Apr 6, 2008 12:51 PM
ef8pro
Jul 27, 2006 10:02 PM
blackflag188
Nov 9, 2004 04:54 PM
erikiksaz1
13
Oct 7, 2004 06:21 AM
elpermgrande
Oct 18, 2002 04:42 PM
