sea foam safe to use on my engine?
Old Oct 25, 2004 | 02:29 PM
crxss outhe eyes's Avatar
Default sea foam safe to use on my engine?
ok, i can tell that sea foam works from all the reviews you guys did, i really want to try it, but im not really sure if i should because my engine burns oil, i have to constantly add at least a half of quart of oil once or twice a week, its a stock d16 and was wondering if i used sea foam on my engine, would it be good for it, or just be bad news. Thanks guys
Old Oct 25, 2004 | 02:46 PM
Spade's Avatar
Default Re: sea foam safe to use on my engine? (crxss outhe eyes)
Using Seafoam at this point would probably cause you to go through more oil cause it will break up the carbon that is helping to block what problems you do have.
Look into picking up a used D16 instead of wasting money on Seafoam.
Old Oct 27, 2004 | 03:35 PM
anyone else?
Old Oct 27, 2004 | 04:28 PM
EGinNY's Avatar
Default Re: sea foam safe to use on my engine? (Spade)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spade &raquo;</TD></TR><TR><TD CLASS="quote">Using Seafoam at this point would probably cause you to go through more oil cause it will break up the carbon that is helping to block what problems you do have.
Look into picking up a used D16 instead of wasting money on Seafoam.</TD></TR></TABLE>
Or pick up a can of stp/anyotherbrand engine treatment (Stuff that looks like molassus{sp} )
CERRITOS.562
21
Aug 10, 2007 08:01 AM
top
Mar 19, 2007 01:31 AM
dpkelly
Mar 10, 2007 11:24 AM
NinjaTech
Mar 15, 2005 02:47 PM
.water
Dec 14, 2004 01:15 PM
