F+R Sway bars on 93 EG Si - SEARCHED ALREADY
1 Post
Ok, cheapest way I can get a nice Sway bar setup on my EG. its a 93 si so i know im at an advantage. I have an ST bar now but its punny and wanted to go TYpe R all around.
1. What fits front EG Si (Now swapped and still have PS ) Direct bolt on?
2. What fits front Si with little mods
3. What fits rear direct bolt on?
4. What fits rear with mod?
What I know/read:
ITR rear bar fits with GSR LCA's but CAN work with 93 civic Si lca's?
ITR Front bar fits Si LCA's no problem so does GSR?
ITR rear bar needs only GSR LCA;s to work?
Other ****.
NEed concrete advice
What I know/read:
Other ****.
Unceasing Measure
Re: F+R Sway bars on 93 EG Si - SEARCHED ALREADY (Truehondacom)
My 1993 Si has a front swaybar already and, coupled with a Suspension Techniques 15/16 rear bar, it is one of the better handling cars I've driven. That's my advice. You can get the rear bar from Summit for under $130 shipped.
You will be much better served by stiffening ONLY the rear sway bar. This will take out some or all of the designed in understeer. Stiffening the front bar, will put the understeer back in.
Try it and see if I'm right, then if you find that I'm just full of crud, then stiffen the front if you like.
Good luck,
Doc
Good luck,
Doc
cranberry
Suspension & Brakes
07-14-2010 10:10 PM
JDMhatchback20
02-06-2005 06:47 PM
