Is my MSD 2 step hooked up correctly? i searched
Old Oct 25, 2004 | 08:09 AM
Rod.'s Avatar
Default Is my MSD 2 step hooked up correctly? i searched
Ok, here is a lil ghetto pic I made on paint brush at work. From the msd 2 step, I hooked the the black wire to a ground. I hooked the red wire from msd 2 step to the momentary push button. The other wire coming of the push button hooked up to a 12v source. Does that sound right? I cant test it right now cause I dont have any pills to test it with.
Old Oct 25, 2004 | 09:31 AM
Rod.'s Avatar
Default Re: Is my MSD 2 step hooked up correctly? i searched (redturbocivic)
anyone
Old Oct 25, 2004 | 11:18 AM
Kataku2K3's Avatar
Yup that's correct unless you're running a Digi10 box, they run negative triggers.
Old Oct 25, 2004 | 01:40 PM
wHOAlly's Avatar
Default Re: Is my MSD 2 step hooked up correctly? i searched (Kataku2K3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kataku2K3 &raquo;</TD></TR><TR><TD CLASS="quote">Yup that's correct unless you're running a Digi10 box, they run negative triggers.</TD></TR></TABLE>
goddam i wish the 6 series ran neg triggers, soooooooooooo much easier to wire
Old Oct 25, 2004 | 01:48 PM
SIXTYdashONE's Avatar
HT's Biggest Loser
Default Re: Is my MSD 2 step hooked up correctly? i searched (Sp00n'd Supra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sp00n’d Supra &raquo;</TD></TR><TR><TD CLASS="quote">
goddam i wish the 6 series ran neg triggers, soooooooooooo much easier to wire</TD></TR></TABLE>
Yeah, wire that **** right to the ebrake wire
Old Oct 25, 2004 | 02:44 PM
Kataku2K3's Avatar
Default Re: Is my MSD 2 step hooked up correctly? i searched (SIXTYdashONE)
I know you've probably seen this if you've searched for 2-step stuff on H-T but here it is again just in case you wanna wire it over the E-brake as Ron said. That's what I just about always do.
Again just ignore the Innovative MSBC stuff unless you're running it too.
red cx
Dec 19, 2005 05:20 PM
Silver.007
Oct 12, 2005 06:50 AM
kodirtysi
Oct 6, 2005 02:45 PM
Drew Peacock
Jul 17, 2004 03:23 PM
JDM R98
Aug 8, 2001 07:47 AM
