FIRST SWAP AND NEED SOME SERIOUS HELP!!!
Old Oct 25, 2004 | 05:29 AM
rwcdrums's Avatar
Default FIRST SWAP AND NEED SOME SERIOUS HELP!!!
Just put a 94 jdm gsr into my 92 cx hatch. At first the car ran fine but kept throwing a code 7. After driving the car about for about 20 minutes it started to go crazy. The engine would cut out and the rpm's would drop and then come back on and if I let off of the gas completely it would die and then I had trouble restarting it. could the tps be causing all of this? I did ideas as to what my problem might be. please help my car has been sitting for 3 months now and I really want to get this thing on the road. any advice would be greatly appreciated!!!!
Old Oct 25, 2004 | 05:46 AM
GiT LaO'd's Avatar
I had a code 7 but never cut out on me...One thing that I figured out early on was some wires on the frontside on my tranny were crossed and caused my car (3 days after swap) to make RPMS go nuts after 4500 RPM and surge the car and then the speedometer went crazy and then the car died and wouldnt start...Next day, thought about it, them wires came to mind as them came unplugged from the senor there...and then VOILA...Nothing ever since....
Old Oct 25, 2004 | 07:31 AM
rwcdrums's Avatar
Default Re: (jaybee)
what wires are you refering to?
Old Oct 25, 2004 | 08:00 AM
rwcdrums's Avatar
Default Re: FIRST SWAP AND NEED SOME SERIOUS HELP!!! (rwcdrums)
thanks for the help, anyone else have any suggestions?
Old Oct 25, 2004 | 08:45 AM
GiT LaO'd's Avatar
It was the wires from a sensor on the front side of the tranny...right behind the radiator...Two wires...Black and Grn/Blk I think...All I know is that Im running fine now...
Old Oct 25, 2004 | 10:30 AM
rwcdrums's Avatar
thanks, I will check those wires when I go home...anyone else have any ideas as to what the problem might be??
Old Oct 25, 2004 | 12:30 PM
rwcdrums's Avatar
Default Re: (rwcdrums)
anyone?
Old Oct 25, 2004 | 01:26 PM
rwcdrums's Avatar
will a tps make the car misfire and stall while driving? I installed a new one before I put the motor in because it got smashed. So I don't understand why it is throwing a code 7....please I'm new at this and need some advice, thanks!!
Old Oct 25, 2004 | 01:35 PM
rwcdrums's Avatar
please I need some advice
Old Oct 25, 2004 | 02:59 PM
muskrat hatch's Avatar
i just did almost an identical swap over the summer and had what seem to be similar problems. it turned out to be the distributor. i got a new one and has been running perfect for a couple of months now.
Old Oct 25, 2004 | 06:48 PM
rwcdrums's Avatar
Default Re: FIRST SWAP AND NEED SOME SERIOUS HELP!!! (chatch152)
could a bad ground possibly be causing this?
Old Oct 26, 2004 | 03:32 AM
rwcdrums's Avatar
anyone give out help anymore?
Old Oct 26, 2004 | 07:31 AM
rwcdrums's Avatar
hello???
UndisputedH22a
15
Apr 27, 2010 03:56 PM
99EeeKay
Apr 9, 2006 10:27 AM
crexer
42
Jan 17, 2006 10:24 PM
rwcdrums
34
Oct 31, 2004 11:17 AM
rwcdrums
Oct 29, 2004 08:24 PM
