Non-factory a/c block off plate.
Old Dec 19, 2001 | 04:00 PM
Willard's Avatar
Default Non-factory a/c block off plate.
I can provide the part number if needed.
Will
[Modified by Willard, 1:02 PM 9/30/2002]
Old Dec 20, 2001 | 01:15 AM
B18C-EJ1
Guest
Posts: n/a
Default Re: Non-factory a/c block off plate. (Willard)
Huh? That looks factory to me
Old Dec 20, 2001 | 04:15 AM
Willard's Avatar
Default Re: Non-factory a/c block off plate. (B18C-EJ1)
Sorry...
Let me rephrase my post.
For those of you that have removed your factory a/c and would like to cover the hole...to prevent the viewing of your header from the front / keep road (debris/rain) off of your header/motor / look stock under the hood.... I will (after getting the info this evening) provide the part number so that you may purchase the cover from the dealer.
Will
Old Dec 20, 2001 | 05:09 AM
Kalokohan's Avatar
New User
I'd like to know where I can get that splash guard under the bumper. The shop tossed mine after the swap.
Old Dec 20, 2001 | 10:08 AM
ESCALVANTE's Avatar
I've had a fabricated one for a while now but it's always falling off. Let me know. TIA
Old Dec 20, 2001 | 07:47 PM
DR. ON POINT's Avatar
Banned
Default Re: Non-factory a/c block off plate. (Guardson3r3)
go to that shop again..I bet u can get someone elses that they threw away
Old Dec 21, 2001 | 06:07 AM
Kalokohan's Avatar
New User
Default Re: Non-factory a/c block off plate. (On Point EK)
I would but Nu-Image sucks and I don't even want to step foot in that shop again.
Old Dec 21, 2001 | 06:15 AM
Banned
hahahahahahahahaha.....u let norris touch ur car...I wouldnt let the ************ hold my dick....might want to get ur motor checked out, its probably stolen
call inlinepro and talk to stan about one of those mudguard things, I think they got a couple lying around
Old Dec 21, 2001 | 11:50 AM
Jackson's Avatar
Sorry...
Will
they make it for ek's too?
Old Dec 21, 2001 | 02:17 PM
Willard's Avatar
Default Re: Non-factory a/c block off plate. (Jackson)
Not sure if any EK came w/o A/C....
For the EG..
Part Number: 74149-SR3
Part Name: "Cover Condenser"
Will
-who likes O.E. chit
Old Dec 27, 2001 | 03:08 PM
Willard's Avatar
Same picture...
Sorry for the bump.
Will
Old Sep 30, 2002 | 09:09 AM
Willard's Avatar
FYI... the installation of a "cardboard and duct tape" version of this block off plate resulted in the coolant temps dropping ~30 deg. F on a B18C5 powered EG.
The car had a Del-Sol radiator and was on track at VIR-Full.
The temperature was sampled from the top radiator hose.
Leaving the heater control valve on resulted in a drop of ~15 deg. F before the block off plate was installed.
Old Sep 30, 2002 | 09:30 AM
YumVTEC's Avatar
For the EG..
Will
Yes, many EK's came without A/C.
Old Sep 30, 2002 | 08:31 PM
Willard's Avatar
Default Re: Non-factory a/c block off plate. (YumVTEC)
Fyi...
"Part Number In Upper Right-Hand Corner:
74149-SR3
Part Name Under Part Number:
COVER CONDENSER"
g2turbo
Sep 29, 2006 05:21 PM
Austinbionic316
Apr 11, 2004 02:37 PM
boost fed ls
Oct 3, 2003 08:24 PM
KooK
Jun 5, 2003 07:46 AM
