any idea on how to clean engine?
i spilled a lil oil on the side of my car engine.... it heats up and smokes ... and smells bad... anyone kno the correct way to clean it?
i'm thinking ... spray it with water... then let the sun dry it... =\
Modified by PartiallyImmortal at 2:24 AM 10/25/2004
but then i cant reach it tho... ill take pix tomorrow morning
and point to where the oil is.. its hella hard to get into... the degreaser wont hurt it right?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PartiallyImmortal »</TD></TR><TR><TD CLASS="quote">but then i cant reach it tho... ill take pix tomorrow morning
No, it just breaks down grease/oils ....you can just let it set for about a min and spray it off with a water hose, make sure you dont do this with your motor hot please buddy....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WrongWD »</TD></TR><TR><TD CLASS="quote">castrol superclean is the best degreaser imo</TD></TR></TABLE>
It's what I use. You can also use Simple Green. Just spray on (scrub with a brush too if you want) then rinse off. Don't let any degreaser / solvent stay on your paint long though.
ok, let your motor cool, until it is decently cool, then spray your degreaser where ever you need to, for the under the hood section and the major parts of the motor and body, just brush over it real quick, then let it set for a min. or so then wash off. I have a pressure washer, and that gets it really clean
damn i have to upload my own pix??? ahhhh sry no pix but then ill try to describe it.... ill draw it out
ignore my drawing it didnt come out right...
WIRES
OIL CAP-... , and TUBES
+----------------+=== | \ //234||+P |
| |=== | \//\ 901- <----|
| engine block | (o)<-' // \\3240u53
| |=======;,'/][;][;[ 2
| |//\vvv }[[vnwov9e20397 0000
| |v ===-/ oooo
+----------------+932u82u Battery here my hand ----> oooo
dammit they should allow picture hosting.... that way u can see how many wires cover up the surrong oil cap area... some are like rubber tubes that barely even wiggle
WIRES
| |v ===-/ oooo
thats the thing im talking about... ty ty ty u mentioned that... there is a lot of wires and like 3 fuse boxes.... 1 on battery has 3 fuses 1 to the right has a lot of fuses like 20? 1 on the upper right of the battery has about 15.... theres crazy amount of wires comming from those... layers and layers then theres tubes for refridgerant and stuff all surrounding the tiny oil cap... i tried tying a towel to a stick... even that cant get in...
with your engine a cold or slightly warm spray it with brake cleaner....it'll get rid of the oil in 2 seconds and dry itself in another 20 seconds. Problem solved, no scrubbing.
dayaftertomorrow33
Mar 14, 2016 07:13 PM
