itr or ctr piston in b20?
does anyone know if my motor would be alright runnin jus itr or ctr pistons on a stock b20? if its not would b16 be alright? also roughly how much of a power increase am i lookin to get? thanx
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hype Vtec »</TD></TR><TR><TD CLASS="quote">so you cant use any OEM honda pistons? like ITR and CTR oversize pistons? If not then what kind can you use?></TD></TR></TABLE>
For a B20B and a B20Z, you will have to go to the aftermarket in order to source different pistons.
The B20A is 81mm, but that's also some seriously uncharted territory with a motor that's not compatible with pretty much anything else (except the B21A).
If you are hell bent on using either of those pistons you will have to get the block sleeved first.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nub.96ek »</TD></TR><TR><TD CLASS="quote">
If you are hell bent on using either of those pistons you will have to get the block sleeved first.</TD></TR></TABLE>
or just get a b18 block
turbociv
May 27, 2005 04:26 PM
