help with d16z6 swap
Old Oct 24, 2004 | 07:33 PM
rasta420's Avatar
Default help with d16z6 swap
does anyone have a pic of a d16z6 intake manifold installed on d16z6 swap? i need to know where to run vacuum lines and also how to use the MAP sensor on the firewall since my intake manifold was missing the MAP sensor on the throttle body.
thanks
Old Oct 25, 2004 | 11:16 AM
rasta420's Avatar
Default Re: help with d16z6 swap (rasta420)
ttt
Old Oct 25, 2004 | 11:20 AM
crx si 2004's Avatar
dont know if this helps but its all i have
Old Oct 25, 2004 | 11:30 AM
Chronicsinners's Avatar
Default Re: help with d16z6 swap (crx si 2004)
kinda related to the topic, what throttle cable is used for a d16z6 swap??
Old Oct 25, 2004 | 11:56 AM
green91's Avatar
you can use a DX cable, but the Si (89-91) cable is preffered
Old Oct 25, 2004 | 12:31 PM
EFz6er's Avatar
Default Re: (green91)
is that pic dpfi or mpfi???
Old Oct 25, 2004 | 12:33 PM
green91's Avatar
that is most definately mpfi.
Old Oct 25, 2004 | 03:09 PM
rasta420's Avatar
thanks for the pic
but anyone have a pic using the z6 manifold and the firewall MAP sensor?
were there any holes that were not used on the manifold? theres one fitting on the back of the IM on the drivers side that looks like its for a vacuum hose...what does that go to?
Old Oct 26, 2004 | 10:10 AM
rasta420's Avatar
Default Re: (rasta420)
ttt
1sikhatch
Feb 10, 2007 09:37 AM
iNetForce
Jun 28, 2004 07:07 AM
SLowCrx
Apr 8, 2004 03:17 PM
green91
11
Feb 14, 2004 04:19 PM
Smoothy
Dec 24, 2002 09:59 PM
