are the d15b7 and d16z6 intake manifold the same?
Re: are the d15b7 and d16z6 intake manifold the same? (iNetForce)
the d16z6 (92-95 Ex/Si) throttle Body has a MAP sensor on it while the d15b7's (92-95 Dx) MAP sensor is located on the firewall
may be other differances as well that I am not aware of, but that is the most obvious..
Electrician
Re: (zanthrax)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zanthrax »</TD></TR><TR><TD CLASS="quote">They are interchangeable.
De Z6 intakemani flows a bit better.</TD></TR></TABLE>
Are you sure? I was looking up on aftermarket intake manifolds for the D15B7 but couldn't find any. I was told that a Mini-Me would help because they make aftermarket manifolds for the D16Z6 and that was the only way since I would be bolting on a D16Z6/D16Y8 intake manifold. If the D16Z6 intake manifold can be bolted onto a D15B7 cylinder head, does that mean I can get a Skunk2 piece and bolt it to my stock D15B7? Any input would be great and sorry for jacking the thread.
Re: (Dimi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dimi »</TD></TR><TR><TD CLASS="quote">
Are you sure? I was looking up on aftermarket intake manifolds for the D15B7 but couldn't find any. I was told that a Mini-Me would help because they make aftermarket manifolds for the D16Z6 and that was the only way since I would be bolting on a D16Z6/D16Y8 intake manifold. If the D16Z6 intake manifold can be bolted onto a D15B7 cylinder head, does that mean I can get a Skunk2 piece and bolt it to my stock D15B7? Any input would be great and sorry for jacking the thread.</TD></TR></TABLE>
all d series single cam manifolds bolt on on all d series single cam heads.
Electrician
Re: (iNetForce)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iNetForce »</TD></TR><TR><TD CLASS="quote">
all d series single cam manifolds bolt on on all d series single cam heads.</TD></TR></TABLE>
So a Skunk2 Intake Manifold that's made for a D16Z6 would bolt onto a D15B7 motor without modification?
Re: (Dimi)
So a Skunk2 Intake Manifold that's made for a D16Z6 would bolt onto a D15B7 motor without modification?</TD></TR></TABLE>
yes
yes
vtec8200
02-21-2009 02:22 PM
99lspwr
06-09-2004 11:53 PM
