something wrong with radiator, plz help
Old Oct 24, 2004 | 07:24 PM
dadado's Avatar
Default something wrong with radiator, plz help
Hi guys,
I have an accord 97 , 4 cylinders, non vtech. The radiator keeps leaking water from the bottom of the radiator. I had check all the hoses and there is no leaking. So i decide to replace the radiator with the new radiator. After installed everything, i take it for a test and the water still leaks from up top. The fan does turn on when it hot. And again i check the hoses, and still no leak. It dripping from the metal of the radiator. I don't how to go about fixing this problem. Plz help, I appreciate it.
thanks
duy
Old Oct 24, 2004 | 07:46 PM
TOP END MS's Avatar
its leaking through the top of the radiator?
Old Oct 24, 2004 | 07:52 PM
dadado's Avatar
Default Re: (TOP END MS)
yea up top at the metal plate
Old Oct 25, 2004 | 07:47 AM
Filthy Focker!'s Avatar
Default Re: (dadado)
2 leaking radiators?!?!?!? If the rad is leaking, take it back to the shop you bought it from...
fs
Old Oct 25, 2004 | 07:09 PM
dadado's Avatar
Default Re: (filthy_shovel)
The old radiator is leaking, so i replace with a new one but then the new one also leak. Yea i will return the new one but my question is , is it my engine problem to cause the radiator to handle exceeding pressure and leaks or is it just happen that the new radiator is suck and leaks. I just wanna ask you guys cuz i don't want to replace the radiator and find out it's not the radiator problem.
duy
vxtirent08
Mar 20, 2008 10:36 AM
IgnitionZ05
May 5, 2007 10:50 AM
FD3S
Dec 15, 2005 08:37 AM
eastsideATX
Jul 6, 2005 02:56 PM
EGh22aEG
Jan 9, 2002 06:37 PM
