Modification of wheel bolt pattern
Heres the deal, I'm looking for a certain style of wheels but they aren't available in the bolt pattern I need. So, here is what I am thinking.
The wheel I want has a 4 x 4" bolt pattern, I need 4 x 100mm.
4" = 101.6mm... This is what I am thinking.
I get the 101.6mm bolt pattern, and I dremel the holes out just enough to where I can get a perfect fit onto the wheel studs. Will this work? Should I spend the money and have a machine shop do this? Or should I not even bother?
I wouldn't do it. depending on the style of the wheel, it could be possible to drill new holes where there are none now, but I wouldn't try dremeling out the lug holes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridvteceg »</TD></TR><TR><TD CLASS="quote">ive never heard of a standard measured wheel size. that 4x4" is your 100mm im betting. they make 4x100 and 4x105</TD></TR></TABLE>
Not Centerline... the closest thing they have to 4x100 is 4x4"(101.6mm)
