HELP...THREW A ROD!
Old Oct 24, 2004 | 02:06 PM
deejaydaze's Avatar
Default HELP...THREW A ROD!
So my brother just threw a rod (i think) in his Automatic 96 civic 4 door. I just wrecked my 96 Manual Civic CX hatchback.
Is it possible to swap motors?
Is it possible to use my parts to fix the problem?
Old Oct 24, 2004 | 02:15 PM
slowestef's Avatar
Default Re: HELP...THREW A ROD! (deejaydaze)
I believe all D-series are interchangeable. So it's a direct swap.
Old Oct 24, 2004 | 02:39 PM
b16ahybrid's Avatar
yes you can swap motors.
Old Oct 24, 2004 | 03:16 PM
deejaydaze's Avatar
Default Re: HELP...THREW A ROD! (b16ahybrid)
even though mine is stick and his is auto....? Have you done this before... not trying to be an azz just in a jam
Old Oct 24, 2004 | 03:17 PM
jdmsiR20's Avatar
yep just take your longblock and switch it with his.
Old Oct 24, 2004 | 03:41 PM
Archidictus's Avatar
Unceasing Measure
Default Re: HELP...THREW A ROD! (jdmsiR20)
Just curious, but how do you "think" he threw a rod. Either he did or he didn't. Usually a gaping hole in the block and/or catastrophic engine issues are a result, so it's not like it's easy to misdiagnose.
But yes. The engines are interchangeable.
Old Oct 24, 2004 | 07:51 PM
deejaydaze's Avatar
Default Re: HELP...THREW A ROD! (Archidictus)
He's 200 miles away....kinda hard to diagnose when he doesn't know **** about cars.
Old Oct 24, 2004 | 07:56 PM
GOLDBERG's Avatar
how hard is it too say if there is a hole in his engine or not??he slowww or something...
Old Oct 24, 2004 | 08:19 PM
BauleyCivic's Avatar
Risky Business
Default Re: HELP...THREW A ROD! (GOLDBERG)
How do you throw a rod in an automatic civic?
Old Oct 24, 2004 | 08:28 PM
Discosteak's Avatar
Default Re: HELP...THREW A ROD! (BauleyCivic)
nuetral a brick and some brake cleaner . or no oil
Old Oct 24, 2004 | 08:29 PM
blaster834's Avatar
GO pick it up
Old Oct 29, 2004 | 07:00 AM
deejaydaze's Avatar
Default Re: (blaster834)
Yeah....thanks for your replies.....both cars are here now that I can look at them. And don't call people slow when you don't know who they are? You are either here to help or to start trouble.
Old Oct 29, 2004 | 09:15 AM
jay.dee.em1's Avatar
Default Re: (deejaydaze)
the swap will work fine .. all you gotta do is switch out the motor itself and bolt the other tranny on
Old Oct 29, 2004 | 10:48 AM
GaiSensai`'s Avatar
Old Oct 29, 2004 | 12:07 PM
Beatkidd's Avatar
he threw a rod in an automatic did he have a CAI ? if so this why i took that **** off my car its not worth the gains
and yes the motor will fit might need some new mounts
Old Oct 29, 2004 | 12:59 PM
anotheredhatch's Avatar
SUCKS ***** THAT YOU WRECKED YOUR EK
Rever21
Apr 30, 2017 08:45 AM
Justin Hays
Sep 22, 2015 07:12 AM
JDMHN8
Other Make Vehicles
Oct 16, 2009 11:50 AM
civic_jones
Aug 31, 2008 11:16 PM
movement01
Mid-Atlantic (Sales)
May 30, 2008 07:00 PM
