Removed AC, what should i do about the evaporator?
Well when I was replacing my clutch, not too long ago i decided to remove the AC, I removed the condenser alll the lines, the drivers side fan, and I just took out the evaporator, (I still need to remove the compressor, because I dont have a belt yet), but I want to keep my heat since i live in minnesota and winter is coming up,
Can I just gut the evaporator and use the ousing around it so the heat will go where its supposed to?
thanks
-Charlie
thanks
-Charlie
I gutted it and covered the hole with the plastic piece and duct tape
you should probably leave the drain hole in the bottom though
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22mark »</TD></TR><TR><TD CLASS="quote">Man how did you get that out, there is so many screws?</TD></TR></TABLE>
I dont remember there being that many
I will buy the evaporator if it will fit a 5th gen accord. I want ac fl is too hot.
Edit: looks like your just pulling it for temp n/m above statement.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SKDRCR »</TD></TR><TR><TD CLASS="quote">I just took the evaporator out and reinstalled the black box/housing
that it was in. My heat works fine
yup thats what I just did!!!!
THANKS ALL FOR THE HELP!!!!!!!<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MEATWAD_00GT »</TD></TR><TR><TD CLASS="quote">Just wondering, but why would you take your ac out for a car your gonna drive everyday?</TD></TR></TABLE>
because I never used it and itll lighten up the car a bit and i live in Minnesota, In the summer I just roll down the windows and open the sunrf
</TD></TR></TABLE>yup thats what I just did!!!!
ive got antire AC kit if you want it i pulled the evaporator and dont need it anymore, ive got a few compressors and all the lines, all your gonna need is the housing around the evaporator which youprobably have, PM me if your interested
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22mark »</TD></TR><TR><TD CLASS="quote">That is under the dash on the passenger side correct? Above the ECU?</TD></TR></TABLE>
yup
yup
good question. This is the last of the AC system left in my lude. I cant wait to hack it!... [monty python voice]..."Off with her head"!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by matix »</TD></TR><TR><TD CLASS="quote">I will buy the evaporator if it will fit a 5th gen accord. I want ac fl is too hot.
Wuss.
Wuss.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Speedra500 »</TD></TR><TR><TD CLASS="quote">how much does it weigh?</TD></TR></TABLE>
The complete ac system weighs around 32lbs
Is loosing ac worth the big 32 lbs. I wich i had ac but i aciddenly trashed my evaporator. I cant wait to find someone parting out a 5th gen accord so i can get a evaporator for my car. I dont have the money to spend like 150-200 for a evaporator.In florida its a must unless you wanna show up every were with sweat stains on your ***** lol.
Keep the evaporator in the kaa if you remove it you remove a critical link in getting air from the blower to the heater unit.
Blower is on the passanger side; followed by the evaporator; followed by the heater unit.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MEATWAD_00GT »</TD></TR><TR><TD CLASS="quote">So thats like .01 second faster and a hell lot off your cars value? I dont see the point but to each his own.</TD></TR></TABLE>
You obviously did not notice the fact that I live in minnesota,
Why carry around an extra 32 lbs, if you never use it, thats like carrying $5 worth of change in each one of your pockets, and never bothering to take it out, because your worth more with it
Plus modifiying your car in general is taking away from its value, and if i was going to sell my car Id sell it to someone in MN that wants a modified car so they probably would not want the AC anyways
this was my reasoning for taking out the AC in my car, im not just gutting out the car so ill run one tenth of a second faster in the 1/4, plus im going for a drag car anyways
