what should I do/need to do to my GSR engine, so it safely handle more boost, etc.?
Old Oct 24, 2004 | 08:23 AM
CrazyModGSR's Avatar
Default what should I do/need to do to my GSR engine, so it safely handle more boost, etc.?
I know this is a vague and kind of dumb question, but I think I want to take my GSR to the next level. My current setup is stock internals and head, etc. with a DRAG Gen 3 T3/'T4 turbo, Vortec FMU (using Hondata or Uberdata in spring), Deltagate wastegate at 7 psi (switching to Tial in spring), HKS BOV and intercooler. Also have an MSD 6AL ignition and cap, NGK plugs and wires, aftermarket fuel pump (don't remember brand) and I believe injectors are upgraded, but I could be wrong. Some of these things are questionable because I bought the car with the current setup. Engine has 80k miles on it. Anyway, I am contemplating the thought of building up my engine to handle more boost. I know that building a stronger engine doesn't mean that it won't blow up, that this still relies on tuning, but if it was properly tuned, at least I feel that I could safely up the boost. I am wondering exactly what should be done to the engine (I would have it sent out to a reputable shop most likely)? I was thinking of having it sleeved, heat-treated (not sure what this entails, but someone mentioned it), pistons, rods, valvetrain, etc.). I want my GSR to put out 400+hp without blowing the thing up and still being a daily driver. I don't really race, I just want more power for myself. Any comments/suggestions?
Thanks
Tim
PS - any recommendations on reputable shops, etc. would be great. And can anyone with a turbo GSR list your setup and about how much it cost?
Thanks again
Old Oct 24, 2004 | 09:12 AM
StolenTeg's Avatar
Default Re: what should I do/need to do to my GSR engine, so it safely handle more boost, etc.? (CrazyModGSR
First thing i would recommended is getting the Hondata or Uberdata first. Then Build the bottom end, I think you will be fine with the stock sleeves, they are known to hold over 400whp. Maybe Piston and rod should do it for you, Some thing like Eagle H beam rod and CP or wesico 9 range compression. Building the motor cause a lot of money if you having the shop doing it, they will properly charged around 1200-1500 for installing the piston and rod alone with all the misc of course.
Old Oct 24, 2004 | 10:26 AM
beerbongskickass's Avatar
Get some larger injectors (maybe 550cc) and uberdata, then up the boost and have your car tuned well. 7 psi on that motor with an FMU is weak. I wouldn't even worry about building the bottom end just yet. Since you don't even race your car building it for 400+ horsepower seems like a waste.
mase1386
Mar 28, 2012 09:06 AM
_Endless_
Jul 16, 2008 01:22 PM
si0385.
Oct 16, 2006 06:32 PM
doc
Aug 31, 2006 04:14 AM
FlatTire
Jul 3, 2004 04:50 AM
