possible clutch or tranny problems
Old Oct 23, 2004 | 08:10 PM
sohctodohc's Avatar
Default possible clutch or tranny problems
ok so i was driving around tonight for all most an hour and i noticed when i was stopped at a red light i went to put it in first and it was hard and when it went in kinda clanked i guess you could call it. and every now and then when i would release the clutch it would stick for a second or two. and going into reverse i had to try probably almost 7 times. and everytime i would try i was at a complete stop and i would put it in another gear then try reverse. would this be a problem with the clutch not engaging woth a **** or is my tranny getting shitty? i havent ever changed tranny fluid would that help? and plus i have a dc sports short throw shifter which i hate. i havent saved enough money up for a skunk2 yet. the dc sports rattles like a bitch and it will barely fit in the shift linkage at the bottom. i put poly urethane bushings one night when i was drunk and did manage to forget the lube would that cause problems?
Old Oct 23, 2004 | 08:16 PM
forced00si's Avatar
Default Re: possible clutch or tranny problems (sohctodohc)
Sounds like oneof the springs in the clutch face has gotten out and in between the clutch and pressure plate.
Old Oct 23, 2004 | 08:21 PM
sohctodohc's Avatar
Default Re: possible clutch or tranny problems (forced00si)
the clutch i have in there is a re-manufactured one. are they pretty shitty? i could afford wut i wanted at the time so i had to go with wut i could afford. and with a spring being out i will have to basically replace the clutch or is it fixable?
Old Oct 23, 2004 | 08:33 PM
sohctodohc's Avatar
bump
Old Oct 23, 2004 | 08:41 PM
SiYouLater's Avatar
its probably the synchros are bad. I have that reverse problem also. Its very common on Honda's.
Old Oct 23, 2004 | 08:46 PM
sohctodohc's Avatar
Default Re: possible clutch or tranny problems (99FBPSi)
yea but there is no synchro in reverse. and it doest grind going into gear either.
Old Oct 23, 2004 | 10:36 PM
forced00si's Avatar
Pull the trans and watch the **** fall all over the ground, after you take the pressure plate loose.
Old Oct 23, 2004 | 10:45 PM
eclypzex's Avatar
master/slave cylinder? i have the same prob(not clutch sticking, but the 1st gear and reverse issues) and was told to put a new master/slave cylinder. ill let you know how it goes on monday/tuesday.
Old Oct 24, 2004 | 11:09 AM
snatchbakman's Avatar
Default Re: possible clutch or tranny problems (eclypzex)
i put in a new clutch and its makeing an kinda grinding noise as i let out the clutch. i bought a new master/slave cylinder i dunno if it is the problem.
hondateg10
Jul 22, 2008 03:54 AM
RTW DC2R
Feb 9, 2004 02:13 PM
Blindstuff
Aug 14, 2003 11:53 AM
J-Brooks
Dec 17, 2002 10:23 AM
sLo B18b
Jul 1, 2001 06:37 PM
