Need your dyno graph to improve my dyno tune!!!!!
This is my Toda A cam with cam gear tuned with Apexi power fc.
This is my Toda B cam with cam gear tuned with Apexi power fc.
I know i can improve between 4000 to 5000rpm with changing the air/fuel ratio. But i have a question. Is it more lean make more power????
When i see the dyno graph as below, I through if i can tune the air/fuel ratio between 13.6-14.2. Is it i can make more power with this setting????
This is another car.
Hope can share with your opinion!!
Modified by Edw-R at 11:45 PM 10/23/2004
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Edw-R »</TD></TR><TR><TD CLASS="quote">
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Edw-R »</TD></TR><TR><TD CLASS="quote">How can i do?? </TD></TR></TABLE>
Looks like you did it right.. wonder if Yahoo! won't let you link out? Try http://www.we-todd-did-racing.com for hosting.
</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Edw-R »</TD></TR><TR><TD CLASS="quote">How can i do?? </TD></TR></TABLE>
what si KW? and what is the conversion to horse power?
oh and anotehr thing...Dynos are Very subjective so do not look at other peoples numbers as a garantee or a measuring stick of what you should be hitting
the curve looks good though
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITRacer121 »</TD></TR><TR><TD CLASS="quote">what si KW? and what is the conversion to horse power?</TD></TR></TABLE>
These questions are irrelevant to his question.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITRacer121 »</TD></TR><TR><TD CLASS="quote">oh and anotehr thing...Dynos are Very subjective so do not look at other peoples numbers as a garantee or a measuring stick of what you should be hitting</TD></TR></TABLE>
If you'd take the time to actually READ, you'd learn that he's not asking for other people's cam gear settings or other similarly useless information.
I would tune the AFR for as lean a ratio as you feel comfortable with. More often than not, you'll find a few more hp when you lean out the mixture.
