Dyno and tune up!!!!!!!
Which gear have more power?? 3rd or 4th? In shootout Mode. Is it the same??
I went to dyno shop. I just get 114kw on the wheel with 4th gear. I ran 82 times on the dyno machine. My modification as below:
Toda A cam
Toda cam gear
Toda valve spring
Mugen head gaskit
Port and polish the head
ARC airbox
5 Zigen extractor and exhuast system
Nology hotwire
HKS twinpower
NGK ird spark plug (rating 7)
Apexi power FC
I need many opinions about this modification, dyno result and suggestion. Thanks a lot!!!!!!!!
Toda A cam
Toda cam gear
Toda valve spring
Mugen head gaskit
ARC airbox
Nology hotwire
HKS twinpower
Apexi power FC
Re: Dyno and tune up!!!!!!! (Edward)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Edward »</TD></TR><TR><TD CLASS="quote">. I ran 82 times on the dyno machine. </TD></TR></TABLE>
Serious?
Serious?
so you made 152.8 horsepower to the wheels? that's pretty bad.
3rd gear will make more hp than 4th gear pulls, usually.
got a dyno chart you can post up so we can interpret the information a little better?
well i know i have toda a cams and cam gears...cold air intake...and a few other small mods...and everything slapped in there without tunning was 160hp...did some wideband tunning not positive but from what others are running around my way i think i got about 185 190.....
Very Emergency!!
Re: Dyno and tune up!!!!!!! (Kal)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kal »</TD></TR><TR><TD CLASS="quote">pretty bad is an understatement for those mods...</TD></TR></TABLE>
agreed......
agreed......
Re: Dyno and tune up!!!!!!! (knalige)
our dynos here in australia read alot lower than your dynos in the states,
different dyno's give different outputs
Edward - those a good number for the mods you have, did u ever do a baseline run? no mods at all?
here in Sydney NSW - standard type r's are about 92-96kw@front wheels
so those are good numbers... IMO
Re: Dyno and tune up!!!!!!! (ek004)
i'm not sure you are right or not. Actually, my standard is 91kw at the front wheel. After i change Toda a cam, cam gear, port and polish, uni-chip and Blitz air filter, i got 99.9kw at the wheel. Andthen, i change apexi power fc, 5 zigen exhaust system, arc intake, hks twin power and hotwire, i got 114kw at the wheel. SO FAR, SO GOOD. I want to show my dyno graph. But i don' t know how to post. Can anyone leave e-mail address to me, andthen i can send it to you. Thanks a lot!!
Need a baseline to do a comparo. How can you people say his power is low when you have NO IDEA what type of dyno he used.
EDIT: ok so 91 baseline - 114 tuned = 23kw 23 * 1.36 = 36.8 hp
sounds like a good gain to me!
