HELP PLEASE CAR boggin, shaking and stall OUT . what could be the problem
Old Oct 22, 2004 | 05:40 PM
DarkBB4's Avatar
Default HELP PLEASE CAR boggin, shaking and stall OUT . what could be the problem
hey alright well my car has beein workin great for a while and today i cleaned my engine bay: I covered everyting up (battery, fuse, distributor, and alternator) with seran rap, and bags and ****). Sprayed it with degreaser then hosed it down. and tonigh i started it up and i knew something was up. It reved to about 550,and begged to stall!! i was confused, but it seemed ok (no engine lights) so i drove the the gas statoin (i had VERY LITTLE gasoline, if this has anytin got do with the problem). On my way, the CAr bogged out, when i tried to accelerate, and didn't know what was up so Pulled over and checkd out my engine, chekd the wires and anyting that was out of the ordinary (oil, or noises?).. and found nothing.... Turned off, then restarted and it appeared to be OK. About 500 feet from the gas station, i went to accelerate a little bit and the car Stalled out, and I lost PS ( thankfully my bro told me that i had lost it, or i would have end up in the curb) I pulled into the station and popped the hood again, just to check ****... NOTHING!!! I filled her up, and it appeared to be working ONCE again, but i was wrong. On my way out it Bogged again, and it through a CEL. This problem led me to believe that it had something to do with my wiring in my VAFC. Possibly my bro, or someone else hit the ecu floor board and put stress on a wire. So i took of my floor board (i didn't put screws in it anyways ) and messed around with a few wires, checkin to see if any were loose and what not.. AFter that , started her up and it worked fine the whole way home... even tho i kept it under 3k the whole time
LOOK at bottom for updates<U></U>
WHATS UP GUYS????
specs/cliffnotes
-recently replaced distributor cap and rotor
-installation of VAFC 2
-Wahshed engine bay
-on way to gas station, car stalled
- Through a cel
-fucked with ECU
-temporarily fixed?
Modified by DarkspeedVtec95 at 4:47 PM 10/25/2004
Old Oct 22, 2004 | 06:04 PM
DarkBB4's Avatar
Default Re: HELP PLEASE CAR boggin, shaking and stall OUT . what could be the problem (DarkspeedVtec95)
up for help
Old Oct 22, 2004 | 06:15 PM
T-Mo's Avatar
It is possible that water got down into your spark plugs. It happened to me before.
Old Oct 22, 2004 | 06:17 PM
DarkBB4's Avatar
Default Re: (T-Mo)
new plugs? thats def a possibility..
would it cause this to stall?
Old Oct 22, 2004 | 07:50 PM
DarkBB4's Avatar
Default Re: (DarkspeedVtec95)
alright kind of convinced that my spark plugs need to be replaced
Would it be alright to drive it lke 10 miles tmw? to and from work ?
Old Oct 23, 2004 | 03:31 AM
DarkBB4's Avatar
please help
Old Oct 23, 2004 | 03:45 AM
vtec92lude's Avatar
I have too say that your car could be fine. If it made it home afterward maybe you just got a little water somewhere. Before you go anywhere let it run for a while (10-15 min) and drive around the block a few times. If no problems pop up take it to work and back. You can change your plugs ASAP if you think that is the problem, but the water is my first thought. If you are runing external coil check it and make sure its not cracked or nothing, and if you are interal check the cap and rotor out.
Good Luck
Old Oct 25, 2004 | 10:36 AM
DarkBB4's Avatar
Default Re: HELP PLEASE CAR boggin, shaking and stall OUT . what could be the problem (vtec92lude)
alrigh well i rplaced the spark plugs and there was WATER in two of the holes... I dried them a little bit witha towel and let them air out for about 30 mins... after that i put the plugs in and test drove.. DROVE FINE&gt;.. the next day.. this is waht happens
i go to accelerat and it DOEST give it gas.. then like 3 seconds later it KICKS IN
WHATS HTE PROBLEM PLEASE HELP
im gonna go chek the plugs for water again..
Old Oct 25, 2004 | 10:48 AM
2lude4u's Avatar
If you tend to let your tank get real low before you fill it, your fuel pump may be worn out. More gas in the tank helps keep it cool. The boggin down may be it overheating on you, then dying. After sitting for a while it cools down, then can run for a bit until it overheats again. I know this is unrelated to the other possibilites discussed, but it is a possibility.
Old Oct 25, 2004 | 10:51 AM
DarkBB4's Avatar
Default Re: HELP PLEASE CAR boggin, shaking and stall OUT . what could be the problem (2lude4u)
where is the fuel pump located, so i can check to see.. (dont really know how to diagnose it)
but all the help will be apreciated...]
u think its ok to drive?
Cause i can JUst put the car into neutral ritght after it has problems... For like 3 seconds, then accelerate and its fine...
It usaully only happnes 1 or2 times for each trip &lt;10 miles
Old Oct 25, 2004 | 02:29 PM
DarkBB4's Avatar
can anyone help
car just stops accereratng then like 5 sceonds later it JURKS in...... WTF
just normal acceloration no WOT
Old Oct 25, 2004 | 03:47 PM
DarkBB4's Avatar
HELP or its goin in the shop
Old Oct 26, 2004 | 11:05 AM
DarkBB4's Avatar
HELP
Old Oct 26, 2004 | 01:28 PM
DarkBB4's Avatar
WENT TO A shop and this is waht he told me
EGR valve could be ****
spark plug wires could be ****.. imma gonna go get some wires... any ideas bout the egr valve...
I heard that you can bypass it, and block it off???? is this difficult?
Old Oct 26, 2004 | 01:34 PM
SKDRCR's Avatar
I doubt it's your fuel pump.
Did you gap the spark plugs?
Who wired the vafc?
I know you said you seran wrapped the dist., but maybe you
should take the cap off just to take a look and make sure no
moisture got in there.
Do you have an external coil?
Did you seran wrap that?
Maybe pull the wire on the coil and make sure there is no
moisture in there.
Just a few suggestions for you. Good Luck
Old Oct 26, 2004 | 01:40 PM
DarkBB4's Avatar
Default Re: HELP PLEASE CAR boggin, shaking and stall OUT . what could be the problem (SKDRCR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SKDRCR &raquo;</TD></TR><TR><TD CLASS="quote">I doubt it's your fuel pump.
YES
Who wired the vafc?
I DID ( not the problem, its been wired for bout 2 months
CHECKED Cap and rotor, seemed FINE
YES
NO- Ill check that right now
moisture in there.
THANKYOU
ALSO: i just called the local auto store (advance auto parts) looin for some ngk spark plug wires which they DONT have.. Butt the guy said he had some "performance" wires that you have to customize (4 cyl) and ut the wires and ****.... sounded a littel shady to me, anyone have any experience with these types.. it hink the brand name is XL
Old Oct 26, 2004 | 01:46 PM
SKDRCR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DarkspeedVtec95 &raquo;</TD></TR><TR><TD CLASS="quote">
THANKYOU
ALSO: i just called the local auto store (advance auto parts) looin for some ngk spark plug wires which they DONT have.. Butt the guy said he had some "performance" wires that you have to customize (4 cyl) and ut the wires and ****.... sounded a littel shady to me, anyone have any experience with these types.. it hink the brand name is XL</TD></TR></TABLE>
Sounds shady to me as well.
I would just find a place that sells the ngk's
Old Oct 26, 2004 | 01:58 PM
delguiner's Avatar
I agree... look for NGK's...
I had a similar bogging problem with my car, it ended up being the EGR valve that stayed open and when the car would be at idle it would shoot excess exhaust gasses in when it shouldnt have, and it caused it to idle very low, sometimes even stall..
So that COULD be a possibility
Good luck dude!
Old Oct 26, 2004 | 02:04 PM
DarkBB4's Avatar
Default Re: HELP PLEASE CAR boggin, shaking and stall OUT . what could be the problem (delguiner)
wow.. sounds very similar...
can u just toss the egr valve ??
i dont want no hot gasses back into the engine?
pleas ehelp so i dont spend 200+ to fix it at a shop
Old Oct 26, 2004 | 02:08 PM
98TypeSH's Avatar
fabricate a block off plate. get a sheet of steel, and some tin snips or a band saw. pull the EGR off, trace the bottom of it onto the steel, then cut it out. dont forget to mark where the holes go. then just put that down, then bolt the egr ontop of it and plug it back in so you dont throw a code, problem solved.
Old Oct 26, 2004 | 02:10 PM
DarkBB4's Avatar
Default Re: HELP PLEASE CAR boggin, shaking and stall OUT . what could be the problem (98TypeSH)
alright.. is this something i could do at my house? or take it to a place??
are they're any gains from this?
advantages?
disadvantages?
Old Oct 26, 2004 | 02:12 PM
98TypeSH's Avatar
lol yea its going to save you from having to replace the damn thing. If you dont have to worry about emissions block it off or get a diff manifold. If you live in some **** state then replace it and take the price right in the pooper.
Old Oct 26, 2004 | 02:17 PM
DarkBB4's Avatar
do you kno of any place that sells one.. becuase im not sur eif i have the skill/tools/ parts for it
Old Oct 26, 2004 | 02:22 PM
DarkBB4's Avatar
is this GOOD?
http://www.honda-performance.c...D=178
i dont need anything fancy tho
Old Oct 26, 2004 | 06:51 PM
limpmode's Avatar
just to add... pep boys should sell NGK wires and plugs, they do here at least
sethb07
Sep 20, 2009 11:38 PM
drewbie
14
Sep 6, 2007 05:47 PM
se93
Nov 17, 2006 03:09 AM
rdiggidy
Aug 17, 2004 05:16 PM
ibe2fly
May 24, 2004 12:24 PM
