GC coilovers on stock shocks?
Old Dec 19, 2001 | 12:27 AM
Duck Sauce's Avatar
Default GC coilovers on stock shocks?
Will the stock shocks hold up ok after installing Ground Control coilovers on them? I heard that Ground Controls were actually designed to work with factory struts. Anyone know? Thanks.
Old Dec 19, 2001 | 05:30 AM
Neo's Avatar
Neo
Default Re: GC coilovers on stock shocks? (www.s4-mtm.com)
It depends in part on what spring rates you order for your coilovers. If you're thinking that you want something stiffer than the stock spring rates, I'd advise against using the OE shocks -- they just don't have sufficient dampening rates to handle an increased spring rate. Plus, I know a few blokes who have blown their stock shocks using after market springs/coilovers. If it were me, I'd error on this side of caution and get a new set of shocks, too.
Old Dec 19, 2001 | 06:36 AM
IC x Prince's Avatar
New User
i just did it...GC's and a set of KYB AGX's...nice combo...nice ride too
Old Dec 19, 2001 | 12:44 PM
Jesse H's Avatar
Get new shocks.
Stock shocks hold up ok to aftermarket springs like Eibach Pro-Kits which are only a moderate drop, and more importantly, a slight increase in spring rates.
Kits like GC are good because
a) You can adjust the height
b) You can specify the springrates
If you're going to adjust the height and specify the springrates to the point that the stock shocks can handle, may as well save money and go with Eibach Pro-Kits. And you won't have the hassle/costs of corner weighing the car with the Pro-Kits as you would w/GC's.
Good luck
Old Dec 19, 2001 | 01:04 PM
Black SVT's Avatar
Default Re: (Jesse H)
No matter what sping rates you get your stock shocks will eventually give out if the car is lowered.
Old Dec 19, 2001 | 03:58 PM
Duck Sauce's Avatar
The Ground Controls I got said "Limited Edition" or something to that effect on the box. What's the spring rate for these? TIA
Old Dec 19, 2001 | 04:09 PM
hybrider's Avatar
i advise to get new shocks, but just to add
my friend has VIS coilovers on stock shocks, prob a 2.75 drop in the front, 2.25 in the back for 1yr+, rides great, no wear
Old Dec 20, 2001 | 01:18 PM
FourDoorGSR's Avatar
My friend was riding with stock shocks on the LE GCs too for a while. His ride was pretty daym decent considering how low it was. But like everyone said. Do it the right way the first time so you wont regret it. Get the KYB AGXs and youll be set. I got the same combo and love the ride. I just hate the fact that the LEs spring rates are sooo soft. Great for daily driving but sucks when you want to take a turn really really hard. hehe
Old Dec 20, 2001 | 02:03 PM
Duck Sauce's Avatar
Default Re: GC coilovers on stock shocks? (FourDoorGSR)
4door: If I get those KYB's and adjust them to the stiffest setting, won't that compensate for the squishy spring rate? The dude that sold them to me told me GC coilovers for Integras and Civics are all "Limited Edition". Unless you opt for the special spring rates which go with Konis or Bilsteins. I dunno...
Old Dec 20, 2001 | 07:23 PM
HondaJon's Avatar
If you order your GC's straight from Ground Control, you can specify if you want Limited Edition or Custom rates, and if you want them made for Koni shocks or not. I just ordered mine from them last week, and I got custom rates and got them fitted for Koni. The rates I got were 400f/300r, and paired with the new ITR rear sway bar I have on the way, I think that my suspension will be very capable of tearing up the turns on the auto x this spring.
I'll let you everybody know what I think of my new set-up when I get it all installed.
Jon
Old Dec 21, 2001 | 05:31 AM
neo1z's Avatar
def reccomend getting shox - youll inevitably blow your stocks, my friend blew two the other day with his progress springs and stocks
Old Dec 21, 2001 | 07:58 AM
I have done that, and don't get me wrong but once you've expereinced stiff springs and know what they can do, you'll never look at a turn the same way again. The GCs LE and KYBs are a great combo for the street. Now if only I wasnt so lazy and installed that ITR rear sway bar sitting in my room, then it'll be all good.
type-ONE
Suspension & Brakes
31
Aug 28, 2009 11:01 AM
kpjo4
Aug 7, 2008 04:30 AM
RJx
Aug 19, 2003 10:21 PM
TypeR1558
Nov 18, 2002 08:32 AM
EKB18BPR3
11
Aug 18, 2002 05:05 PM
