Draining The Coolant
Old Dec 20, 2001 | 01:56 PM
Pat's Avatar
Pat
Default Draining The Coolant
Time for me to stop procrastinating and finally change my coolant, couple of questions though:
1. THe engine drain bolt, is it that big bronze bolt on the front of the block, behind the ex. manifold?
2. Is it difficult to remove (looks real tight and awkward to work around behind the header)?
3. SHould I drain the coolant with the car level or will just the front up do?
TIA
Old Dec 20, 2001 | 02:16 PM
TrustGs-R's Avatar
New User
Default Re: Draining The Coolant (Pat)
1)sounds about right...but mine's not really behind the exhaust manifold. Maybe behind a corner of the manifold.
2)yes it's pretty tight usually. Hook up a good breaker bar.
3)You dont need to really lift any part of your car, but if you want to be sure/thorough, sure...life the back let it drain, lower it, lift the front, let it drain.
Old Dec 20, 2001 | 02:28 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Draining The Coolant (TrustGs-R)
Just drain the coolant on the radiator. There is a drain bolt on the bottom of the readiator next to the lower radiator hose.
The older integra had a bleader valve there, but acura felt it wasnt needed so you should have one on the radiator.
art
Old Dec 20, 2001 | 02:31 PM
TrustGs-R's Avatar
New User
Default Re: Draining The Coolant (Arturbo)
i happen to have one of those older tegs
the radiator drain does a bad job of bleeding your water jackets.
Old Dec 21, 2001 | 08:03 AM
dynamite C1's Avatar
sure the "SEARCH" function really helps! I was about to post this questin too...thanx for the info ppl now lift drain drop life drain drop
whiteGSR
Jul 26, 2022 03:06 PM
MrViet
Oct 20, 2009 09:43 PM
LAKER HATER
Nov 24, 2004 07:13 PM
magic hat #9
Sep 4, 2002 12:39 PM
CivicBoi
Jul 27, 2002 10:49 PM
