a squeaking nosie in my clutch
Old Oct 22, 2004 | 12:24 PM
IntegraLs94Cam's Avatar
Default a squeaking nosie in my clutch
whenever it rains my clutch makes a squeaking nosie whenever i push it down .... does anyone know how to make it stop squeaking!!! it drives me nuts and makes my car sound like ****.
Old Oct 22, 2004 | 12:57 PM
six_speed's Avatar
Have someone stand infront of the car an dlocated the sound. If it's at the slave cylinder then the grease is all gone off the clutch fork(very common) where the slave cylinder pushes. If it bothers you that much open up the slave cylinder and put some grease on clutch fork's "(indent) where the slave's cylinder pushes on.
Old Oct 25, 2004 | 06:46 AM
Default Re: (Humping_dragon)
hey im kinda new to all this so i dont know where that thing you are talking about is.... when i open my hood and look in the engine bay where is it located at? im a noob sorry
Old Oct 25, 2004 | 05:02 PM
Default Re: (IntegraLs94Cam)
bump
Old Oct 27, 2004 | 05:10 AM
wow bump
Old Oct 27, 2004 | 05:23 AM
ian.'s Avatar
It can be just the return spring on the clutch pedal,
or it can be the contact point of the clutch pushrod with it's master
cylinder.
Old Oct 27, 2004 | 05:25 AM
Default Re: (IC33)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IC33 &raquo;</TD></TR><TR><TD CLASS="quote">It can be just the return spring on the clutch pedal,
cylinder.
Where is the master cylinder located at?
Old Oct 27, 2004 | 08:02 AM
loadedB18C's Avatar
Default Re: a squeaking nosie in my clutch (IntegraLs94Cam)
Locate the squeeking from the front of the car and then! Once you have fount the clutch fork put grease in it this problem is very common and it happens to all tegs. Happend to mee about 4 to 5 weeks ago and I had to do the same stuff.
Old Oct 27, 2004 | 08:04 AM
loadedB18C's Avatar
Default Re: a squeaking nosie in my clutch (loadedB18C)
It is located way at the bottom on the top right of the engine manifold. Right passed the Valve Cover.
Old Oct 27, 2004 | 08:05 AM
loadedB18C's Avatar
When you look back there you will hear it sqeaking trust me look up there and you will know what I am talking about!
Old Oct 27, 2004 | 09:54 AM
what kind of grease do i use?
ohsnapzafingcu
May 16, 2011 04:30 PM
curtie94
Apr 10, 2011 12:47 PM
b16a4
Nov 18, 2006 11:04 AM
puertoroc7976
Sep 7, 2006 03:06 PM
s1ngle
13
Sep 21, 2005 12:01 PM
